Question about RCA 32F531T 32" TV
Rca flat scren hd tv
Comes on for a while then turns itself off and and will not come back on untill its off for a while.
    Genius:
  • 1,694 Answers
Examine horiz circuit with magnifier.....look for bad solder
connection.............check power supply area and solder pins of
horiz output transformer.............T.
Posted on Mar 21, 2008
Techwood 42in tv model 42832 hd digtal it turned itself of,cant get no picture,but blue stand by switch still turns on and off
It sounds like your TV's display has been routed to a different INPUT than the Cable/TV input jack, like a VCR in put or an RCA input. You need to change the input back to TV from VCR or LINE1 or RCA, so on. How to do this without the original remote, you are going to have to look up the program code for the universal remote and program that remote correctly, once done, change the TV Input until you're back on cable.
Mar 29, 2011 | Televison & Video
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Just purchased RCA HD Tv. What is the RCA code
We would be happy to help you with getting your DISH Network remote to control your RCA TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your RCA TV here are some of the codes we currently have: 503, 627, 633, 725, and 505. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your RCA TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | RCA DISH Network(r) 311 Satellite System
RCA TV 27V530T ON OFF
Sometimes are an eeprom corrupted andneed to be changed
May 09, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Flat scren TV 46 inchs.
Your TV may be defective.
Jul 20, 2017 | RCA 20F530T 20" TV
RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
Sep 15, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
TV turns its self on and off
Greetings. I had the same problem with my 29" RCA, and it was easy to repair. I opened the back cover of my tv and just disconected the two wires cable that connect with the upper controler (volume, chanels, etc); and now it is working OK; but I must operate the tv only with the remote controler.
I hope this could help you.
German.
Jul 17, 2008 | RCA 20F424T 20" TV
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
TV turns itself off and then back on when I watch HD
If it played OK before you replaced the video board and now you have an intermittent problem Suspect the part that was replaced...Does this set have a video board? I can't find one on my parts list. Also there are a lot of ISSUES with aftermarket lamps not working properly on hi bright pictures. I can find out correct part #'s with complete model #.
Nov 18, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
RCA 32F531T 32" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
