Question about T-Mobile Sidekick ID Cellular Phone
Sidekick 11 not charging
My sidekick wont charge from either the house or car phone
  • Anonymous May 01, 2008
    my sidekcik 11 isn't charging
What you have to do is find a spot that it will charge and tape it down. That's what I did and it works relatively well.
Posted on Nov 28, 2008
6ya staff
SOURCE:
My sidekick 3 won't turn on and i just got it today
Oooh, bad news. You probably got a sidekick 3 that had a bad charging port. Return for a refund if you can.
the Sidekick 3 has a charging issue thatcrops up after awhile. It will just not charge the battery.A good way to tell is if the orange light comes on but the phone never charges.
You can get an external battery charger for the sidekick for about 25 dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 13, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Hey
The sidekick has an issue with its charging port going bad. Do you get the orange light when you plug it in?
It about 80 dollars to get fixed or you can do a workaround for about 30 dollars.
What you need to get is a charging cradle that has a spare battery charging slot. This will you allow to charge your battery seperate from the phone. I also recommend getting a second battery so one can be charging at all times.
Here are some links for the charger and the batteries:
Sidekick 3 Battery Charging Cradle
New Spare Sidekick 3 Battery for Sale
Hope that helps
Dec 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont charge
Michael-
Hope that helps
Dec 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick wont turn on
that happened to me before.
all u have to do is take ur sim and battery out and then wait for 5 minutes and re enter them into ur phone...!
Oct 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick wont charge
wakesk8er02
The sidekick 3 has a known issue with the charging port going bad. The orange light will usually come on but it doesn't charge the battery.
you can try www.cellulardr.com or you can do a work around that will cost less.
Most people will buy a cradle charge that has a built in spare battery charging slot. This allows you to charge the battery seprate form the phone. ?It is about 25 dollars on ebay. Its also a good idea to get a spare battery so you can have one charging at all times.
Sidekick 3 Spare Battery Charger
Sidekick 3 Batteries
Jul 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Ayy
Is the orange light coming on but you have no power? If so, then it is probably not charging. The sidekick 3 charging port is notorious for going bad. The little contacts that send power to battery come loose.
Find a friend that has a sidekick 3 or sidekick ID and try out their battery. If it powers up, it is your charging port.
The easiest thing to do is to get a charging cradle that has a spare battery charging slot. They run about 25 dollars off off ebay and allows you to charge the battery seperate from the phone. A spare battery is good too as it allows you to have one charging at all times.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Sidekick Spare Batteries
Jun 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Side kick 3
The sidekick 3 has a charging problem on some models.
It's not the battery or the charger but the battery charging port.
Call t-mobile if it is under warranty.
If not you can use a work around that charges the battery outside the phone.
Check out this site for more info.
Sidekick 3 charging problem
Nov 22, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
32 people viewed this question
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Damen Wong
Damen Wong
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
