Question about Cameras
Would like to purchase a USB cable to be able to transfer pictures from camcorder to computer (vl-ah50u)?????
  • 3,037 Answers
Just go to any electronics store like best buy or circuit city or to there websites and they will have the cable you need.
Posted on Mar 19, 2008
SOURCE:
The tape on my Sharp Viewcam VL-AH50U keeps ejecting
i think it could be the latching system im not sure if its electronic latch or spring start by looking there if its electronic latch take it in to a shop if its spring latcg maybe the end of the spring just needs putting back on
Apr 24, 2010 | Sharp Viewcam VL-AH50U Hi-8 Analog...
I want to transfer my videos taken on my Sharp
You will need a firewire cable and a firewire port on your computer. If you don't have such a port then you can buy a firewire pci card.
See this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Feb 07, 2010 | Sharp Viewcam VL-Z1H Mini DV Digital...
Model VL-E65OU - how can I burn DVD from the 8MM cassette tape into my computer? Can I purchase a TV cable that will go from TV to computer? Would I need software in my computer to do this? OR can I go...
1. You need a firewire cable to connect camcorder to the computer.
2. Use the CD that came with the camcorder to install drivers.
3. The computer will detect it when you power ON the camcorder.
4. Use Windows Vista MovieMaker (free) to transfer and "edit" video and/or create a DVD disc
Sep 01, 2009 | Sharp VL-E650U 8mm Analog Camcorder
I want to connect my viewcam VL-Z3 to my latop, but I dont have a driver to support it. Can you help?
I had this problem too.
I searched the web high and low. Even wasted 2.99 on what claimed was the driver but turned out to only be instalation directions.
From what I understand, Sharp no longer supports camcorders, so obtaining the dirver from them is out of the question.
Connecting your camcorder to your computer via USB is only used to transfer photos from your SD on your camcorder. You cannot transfer video via this method.
Here`s what I did to solve the problem of not having the driver.
I got a $10 SD card reader for my computer and this solved the problem.
To transfer video from your VL-Z3U to your computer, all you need is a firewire cable .
Assuming that you have a firewire port on your computer, simply connect your camcorder to your computer via firewire, power up your camcorder and your computer should automaticly recognize your device.
You can now transfer video to your computer using your normal video capture/editing software.
Hope this helps
Aug 07, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Want to transfer videos from a mini DV cassette to computer.
Hi
Basically what you need is a video card in your computer. Then you can connect your AV/S cable from the camcorder to the computer video card. When you buy a new video card, it usually comes with a free basic editing software which you can use to capture the video on your computer. Hope this helps.
May 27, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder to computer transfer
I ended up buying a CyberLink DVD Maker kit.
Apr 05, 2009 | Sharp VL-E630U Camcorder
YOU NEED THE SHARP CD-ROM TO LOAD THE VIDEO DRIVERS ON YOUR COMPUTER TO RECOGNIZE THE CAMERA...PART # IS CDSKAA028WJ01
Dec 24, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have a jvc model number GR-D770U AND IM TRYING TO TRANSFER what is on the cassette to my computer with the usb cable how do i do it.
Your camcorder is only able to transfer still pictures with usb,if you would like to transfer a video you must use a DV input on a computer.If you would like instructions on how to transfer still pictures using the usb.Install software that was included with camcorder then make sure your using the adapter instead of battery otherwise you may run out of power,then make sure your unit is turn off then plug in usb cable to computer.After plug unit in turn on camcorder and use software provided to transfer pictures.Never pull out memory card when plug in to computer and make sure you do not unplug cable while arrow signs pointing right and left on view screen.I hope this helps you out happy picture taken.
Jul 29, 2008 | JVC Cameras
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
