Question about Xerox DocuColor 12 Color Copier
Docucolor 12 spills fuser oil
I have a Doc12 and it spills fuser oil on copies, what can i do?
The doner roller blade is faulty clean it or replace it
Posted on Jun 19, 2008
The most common cause, the oil pipe is blocked. black rubber hose. Use a cable tie or some such to clear out any paper dust and congealed oil. Should be no need to repalce fuser parts.
Posted on Mar 21, 2008
  • 2,072 Answers
Pretty much all you can do is rebuild the fuser, either the meterins blade or wick are work out.
Posted on Mar 20, 2008
  • Rick Kasper Mar 20, 2008
    Sorry its called the metering blade. Mispell ..It dispenses the proper amount of lube.
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
Doc12 prints only black but copies fine?
This is a critical issue, for which I need to post long texts and we might need to communicate at regular intervals for which the direct service is very limited to answer to such issues.
Thus, please understand the circumstances and I request you to join an email / chat session with me. Solution will be fast and cheap. You will also get a refund if you are not satisfied.
Nov 08, 2011 | Xerox DocuColor 12 Printer
I installed a new fuser oil cartridge in my Docucolor 12. After about a week I found the oil was low again and we had only made a few hundred copies. When we pulled the unit away from the wall I found...
u need a new oil tank. this is the yellowy/brown plastic bit where the oil sits in. if not you might have a blockage in your oil system in the fuser itself causing it to spill out. if the oil is on the trays its more than likely the oil tank
Jun 18, 2009 | Xerox DocuColor 12 Printer
DC 1250 Paper Jam when printing few copies
Well that problem is because there is not enought oil on the fuser roll. The problem is the oil pump. change it before make one irreversible damage to the fuser or pressure rolls. Do a full maintenance of the fuser module.
Apr 25, 2009 | Xerox DocuColor 12 Printer
Doc12 Upper Fuser Roller
that roller will need replaced along with replacing the wick and donor roll. The teflon wears and the ink sticks to the roller instead of peeling off.
Here is a link to order parts and get very good and professional people to deal with. This IS NOT me or where I work, but the best I found bar NONE for Xerox parts, When you call ask for Britt.
Apr 26, 2008 | Xerox DocuColor 12 Color Copier
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Xerox Doc12 10-386 error code
That is a fuser overheat. Make sure that the paper path module is securely locked into place.
Look for a piece of paper wrapted in the fuser.
Or replace the fuser itself.
Apr 11, 2008 | Xerox DocuColor 12 Color Copier
Doc 12 fuser oil leaking
It needs to have the fuser taken apart and rebuilt.
There are wicks and wiper blades that wear out.
Then they do you get excessive oil on the paper and
pretty much everywhere.
If your doing it yourself I can provide you a good and reliable vendor.
Apr 07, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
206 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
