Question about HP OfficeJet 7410 All-In-One InkJet Printer
Printer is not working after changing the router
Hi
I have HP officejet 7410 printer installed as wireless printer.
For some reason i replaced my router with new router with the same setting and password. All my wireless connections in the laptops and desktops are working fine except for the printer.
Please help.
  • 1 more comment
  • nagureddi Mar 19, 2008
    need help with HP officejet 7410 printer
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    May i know the IP address of the Printer.
    To know the IP address.
    Press setup->Network->Print network Configuration page.
    Printer will print a page, there you will get the printer IP address.
    With the IP address range we can determine what is the problem.
    If u get an IP address like (eg)192.168.1.3.Open the Internet browser and typeHttp://the printer ip address (example http://192.168.1.3) Press enter.You must see the Printer profile.
    Please reply me
    Always Glad to help
    Riz
  • Anonymous Mar 21, 2014
    need help connecting my printer to my wireless router
I'm still waiting to hear back from HP or Netgear. For some reason, the router does not support this HP model and their site (the link noted) does not offer a solution.
Posted on Apr 09, 2008
    Novelist:
  • 188 Answers
Hi Nagureddi,
Please click on the web link given below and perfrom the steps as given in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00805046&cc=us&lc=en&dlc=en&product=391194
Have a great day!
Posted on Mar 24, 2008
SOURCE:
How do I set up the 7410 for wireless printing?
Please click on the below link which provides the installation instruction for setting up 7410 AIO printer on a wireless network.
SETUP Instructions
Regards,
Riztech
Mar 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Printer will not printer wirlessly from any labtop I have I have HP 7410 all in one printer.
hi there,
you may check the wireless settings on the router first and make sure to put those settings either into the software of the printer or the printer itself which is on the LCD screen of the printer.
You will be needing to know the ff:
SSID
Encryption key/ password
for you to be able to set this up. Once it is setup, you may check the IP address of the printer into the router setup screen under status, LAN sub tab and then DCHP clients table.
Install the software/driver into the computers that are working on the network and then it may detect the printer automatically or you can do it manually on the computer by assigning configure port. after doing all these, try if you can print.
Note: the port you should use is the Standard TCP/IP.
Jun 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Connection to network
Hi.
try to use the Software CD to add the printer driver. Choose, "ADD A DEVICE" when window pop-up after inserting the SW CD, then follow the steps to install the device. That should work.
sincerely yours,
adonscott
Jul 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 off line with Vista & HPM8000 computer
Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
After installing the patch restart the computer and check for the result.
Jun 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printer
IP address may need to be changed on the printer.
if you have the printer setup for Automatic.. just restart the printer. If you have it setup for Manual, you'll have to assign it a new IP address.
Mar 19, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 can't print anymore
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Dec 17, 2007 | HP OfficeJet 7410 All-In-One InkJet...
WiFi Print Server, how do I configure?
I purchased this machine and went through two months of technical support, new drivers, uninstalling and installing software, new install cd from HP (that was older than the one that came with the machine) then finally a replacement printer - still no wireless capability with my compaq v2000.
Chased it all the way up to US senior support and a woman told me there that the wireless peer-to-peer feature only worked 50% of the time. She told me to buy a router - end of story.
I'll never buy another HP printer again, and I'll never spend the money on upgrading to peer-to-peer wireless for a printer again!
So - get a router and follow the instructions, and it'll probably work.
Dec 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
850 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
