Home | Brother | IntelliFAX 2600 Fax | Dark line
Brother IntelliFAX 2600 Fax
Problem for Brother IntelliFAX 2600 Fax
Dark line
By mtcsc on Mar 19, 2008
When faxing, the receiver is getting dark lines on the left side of the copy? Do I need to replace the drum in the Brother Intellifax 2600 (if there is even one?)
Same Problem
Jun 13, 2008
-   I REMOVED THE CARTRIDGE & DRUM AND CLEANED THE GLASS. WHAT OTHER AREA WOULD I NEED TO CLEAN?-   pwhitlow
Solution #1
posted on Mar 19, 2008
Not Rated)
mccloud1
Rank: Apprentice
Rating: 0%, 0 votes
If the line is not on your recived faxes then you need to clean the area the paper passes over when sending. any marks could cause this.
Was this helpful?
Yes
No
Popular Solutions for Brother IntelliFAX 2600 Fax
Questions and Unsolved Problems for Brother IntelliFAX 2600 Fax
Do you recommend Brother IntelliFAX 2600 Fax?
Answer
Answer
our fax machine is only printing in the middle of the page. the toner cartridge is new too.
Answer
my brother intellifax 2600 can not work
Answer
I need to find replacement paper output pieces for my brother intellifax 2600. they have one of the... (More)
Answer
How can change my Brother 2600 from F/T to FAX mode?
Answer
When I send a fax, the machine does not make the usual modem sound. Thanks.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Brother IntelliFAX 2600 Fax:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 1493
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
