Question about RCA 32F531T 32" TV
Tv shuts down
The tv will come on with good picture,stay on for a little while then shuts off, then when you turn it off and back on it will not come on. but wate hour or so and it will come back on for a while. could use some help here.. thank you
    Sergeant:
    Champion:
  • 375 Answers
Your tv is ******** down because of cold solder connection on the main pc board.possible around the horizontal section.
Posted on Mar 20, 2008
I have a WD 65738. While viewing a program, the color becomes distorted, along with a humming sound. Status light stays green.
Hello, it sounds like your color wheel is going bad. the humming noise is usually the bearing in it going bad and it starts to distort the image and finally it will shut the set down because it is malfunctioning......tks
Jan 15, 2015 | Mitsubishi WD Televison & Video
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Set comes on with a blue screen with retrace lines,then shuts down. Turned down screen control on flyback, set stays on cannot control brill
The set is shutting down because the picture tube is been over driven, it is most likely the picture tube has a short in the blue gun, turning down the screen control drops the voltage to a safer level. The only other possibility is a short video driver and open feed resistor usually located on the video board on the back of the picture tube.
Feb 23, 2011 | Sony KV-32S40 32" TV
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV shuts off
prob  erratic connection  on pc board finding same problem.
Nov 24, 2008 | Samsung HL-P6163W 61" TV
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
On / Off problem
YOUR ON/OFF BUTTON ON THE FRONT PANNEL IS STUCK
SOME HOW (PRESSED IN ) TY SOME WD40 ON IT . SEE IF THAT WORKS.
Dec 12, 2007 | Samsung TXP3275H 32" TV
The picture is to bright
if you are a tech open the tv and turn down the brightness from off the flyback screen adjustment if that does not work then the flyback will have to be replaced.it is defected.good luck
Apr 19, 2007 | Emerson EWF2703 27" TV
RCA 32F531T 32" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
