Question about Compaq AlphaServer DS10
DS10L AlphaServer CPU Fan Failure
Symtoms:
System powers on but fails the self test and wont reach the SRM prompt.
Event and FAN LEDs are lit
Actions so far.
Retrieved status from RMC with CPU Fan: FAIL indicated.
Replaced CPU fan assembly with out any luck.
I have o-scoped the leads from the CPU fan and I'm getting
12VDC on the red wire.
5VDC pulse on the yellow wire
~0VDC on the blue wire
I'm looking for any further trouble shooting ideas.
The answer is to get hold of a high-speed case fan. I used a Scythe s-flex 80mm which has a +/- 5% RPM of 2800. rearrange the pins or use a choc-block such that yellow -> black, red -> yellow, black -> red. Hey presto.
Works for me.
Posted on Jul 04, 2010
Asus P8C WS error code 55
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
When a computer completely fails to boot or to provide any sort of power on self-test (POST) beep codes, the cause is either a hardware failure, lack of power or a bad connection.
To solve these problems, it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer.
From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them.
Test the AC power to make sure there is power to the outlet. Inspect the back of the power supply to ensure the power cord is fully seated, the power switch is on and the voltage setting is set to the right voltage, which is typically 110 volts.
Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located.
Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system.
This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
Disconnect the drives and remove all of the expansion cards except for the video card, and try to boot with a bare system composed of only the power supply, motherboard, CPU and cooling fan, RAM, and video.
Attempt to start the computer again. If the system boots, reinstall the removed items one at a time until the system again fails to boot, and then replace the component that is causing the failure.
If the bare system fails to boot, swap in known good components for the motherboard, RAM, video card, power supply and CPU until the system boots.
Swap components into a working computer one at a time until that system fails to boot in order to locate problem components.
Hope this helps.
Nov 22, 2012 | ASUSTeK COMPUTER ASUS P8C WS - Motherboard...
My hp pavillion dv7 keyboard lock lights keep flashing; at one point the computer didn't want to boot up; I finally got that up today after six months. But the cap lock and the number lock lights still...
those are POST code, error codes, you need to watch time and count them. report them.
leave the battery main out.
does it run ok now? yes/no.? main battery out?.
even new cheap batteries fail easy and hard and short out.
test it with no main battery. it can run on AC power for ever.
are you going to run the COIN cell RTC battery for 10 more years.
it wont make it..
this PC is 10 years old today (can be) so is RTC battery end of life. most fail in 5 to 7 years, says the pink bunny. (and is correct)
the manual shows how to replace it at the real HP Site,
fixya is not hp, not at all.
page 63 shows the way to the RTC
http://h10032.www1.hp.com/ctg/Manual/c01918142
if you power on the PC, and hammer the f10 key]
BIOS runs, its menus;
check the time and date here, if wrong the RTC battery is dead.
read page 3 how.
http://h10032.www1.hp.com/ctg/Manual/c01662442
  • old PC have many points of failure (endless it seems)
  • does the fan run? is it packed in lint, as all are this old.?
  • causing it to overheat?
  • RTC coin cell bad.
  • main battery bad. (just leave it out until the PC runs right again)
  • power pack wires broken, or running real hot.
  • HDD going bad,
  • windows infected?, no OS stated but avoid XP.
HP caps lock POST blink code page is a horror of horrors
no 2008 listing, to name one flaw (2011 and newer sadly)
https://support.hp.com/us-en/product/hp-pavilion-dv7-1100-entertainment-notebook-pc-series/3756677/model/3807256/document/c01732674
here is a old post at HP, one guy 3 year ago said
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure (RTC coin cell dead)
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times (or RTC dead)
System board
General system board failure
LEDs blink 6 times (or RTC battery dead)
BIOS
BIOS authentication failure
Feb 15, 2018 | HP Pavilion dv7-1132nr Notebook PC
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
HOW TO GO TO BIOS SCREEN
I am not very familiar with Alpha. Do either of these manuals help? Here is a Console Reference and a Console Firmware guide that talks about it.
Thanks
Mar 11, 2010 | Compaq AlphaServer DS10
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
I had a loud fan noise coming from inside my desktop box for a while. One day (& ever since,) when I went to turn the box on, absolutely nothing happened: no fans, no BIOS, no LEDs. I made no config...
This may work however i think by ignoring the sound of the Fan you might have destroyed the cpu and the motherboard.If you can try the processor in another machine you might just have to replace the motherboard only.
Good Luck
Dec 03, 2009 | Intel Motherboard
Power Reaching the MB but NOT reaching the cpu fan
Either replace the line to the fan (or get a new fan with a longer cord )or leave the side door of your CPU off a bit and maybe put a fan beside it.
Jan 06, 2009 | ASUS P5PE-VM Motherboard
Motherboard Problem?
Chances are that until you solve the problem with the CPU fan, the system will not boot. Is the fan plugged in? Most CPU fans plug into a special connector (known as a "fan header") on the motherboard (the connector is often labeled "CPU FAN"); CHECK CAREFULLY to be certain that the fan is still plugged in properly... If you can get the fan to work again, the system just might boot up and begin working again... if you can't get the fan working properly again, buy a suitable replacement; whatever else you do, do NOT try to run the computer without a working CPU fan. Good luck; hope this helps you sort out the problem...
Apr 01, 2007 | Intel D850MV Motherboard
Compaq AlphaServer DS10 Logo
610 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
