Question about Edirol UA-4FX External Sound System
Problem sir, i've just install windows server 2003 but the problem is my sound driver and printer driver is not supported for windows server 2003 sound driver - realtek printer - hp deskjet F300
  • 655 Answers
For realtek sound driver click here (please confirm your model no. before download)
For your printer driver click here (enter your model no. and make download.
You can choose the drivers for your OS i.e. Windows Server 2003
I think it will fix your problem.
Thanks
Iqbal
Posted on Mar 19, 2008
SOURCE:
Print spooler automatic it will stop
From Microsoft: http://support.microsoft.com/kb/934885
I dont know how your print server is configured but you may want to see if the manufacturer of the printers have any updated drivers or try older version of the drivers. If just printing you may want to set the printer to a TCP/IP port and use generic print protocols.
Dec 17, 2012 | Microsoft Windows Server Standard 2003 for...
Can't install network driver for Intel DZ77BH-55K for Windows Server 2003
Intel 82579V Gigabit - Found on Intel download center, and chose Windows Server 2003. Web site will filter choices. Good luck.
Sep 18, 2012 | Intel Corporation Computers & Internet
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
Printers hp1560 drivers does not installed on server 2003
Hi, unfortunately HP does not provide a driver for Windows Server 2003. Your only options for installing this printer is to try one of the other drivers (such as XP or Vista), or finding a similar printer that does support Server 2003 and using that driver instead. Since most drivers use the PCL language, you may be able to get away with using another printer's driver (though you may lose some functionality).
Nov 20, 2010 | HP Deskjet D1560 InkJet Printer
Want to install hp deskjet 1560 driver on windows 2003 server
right click the driver setup file and click on properties. In the properties window go to compatibility tab and choose 'run this program on compatibility mode' and select windows xp. Now click and try running the setup again. Hopefully it might help you solve the problem.
BestRegards NextDoorNerd
Jul 28, 2010 | HP Deskjet D1560 InkJet Printer
Audio/sound driver for windows 2003 server operationg system
Go to: http://support.dell.com Enter your service tag# for your Dell machine, navigate to drivers/downloads, select driver for sound card and install.
gurutim
Mar 21, 2009 | Computers & Internet
I purchased compaq cq40-108tu want to install windows 2003
I am not very sure, why you are assuming to install windows 2003 because windows 2003 is server and i really dont recomment to install it in Laptop.
and you have not mentioned what driver you want to install on it. usually, sound driver does not come along with this OS becasue it's for server purpose not for clint so.
and if you any want to install this driver you can download from your manufacturer website.
and if you have recovery disk you can install from there manually too.
thanks
Dec 27, 2008 | Compaq Presario Notebook
TOSHIBA e-STUDIO16/20/25 PCL 6 Installation Problem Mac OS.
You will need to do it through a server LIKE WINDOWS 2003 SERVER , and set up a print server role on it, this allows multiple protocols to be understood ,, including windows, linux, mac, os2 freebsd etc...
Jan 17, 2008 | Office Equipment & Supplies
Edirol UA-4FX External Sound System Logo
70 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
