Question about Thomson 26943GE1 Cordless Expansion Handset
GE Model 29265 Trimline Memory Phone
I have 4 of these, brand new! I get a dial tone, and on some of them I can hear a caller, but I cannot dial out. I tried to program them; it appears that it's important that tone, not pulse be selected, but touch tone is the default option, anyway? I can't believe a simple handheld line line fon could be this much trouble. P.S., we still have phone service, by using our cordless phone.
  • Anonymous Mar 29, 2008
    I am appalled at the spelling errors in the instruction booklet for the GE 29265. Someone should proofread for mistakes before printing the instructions. As an example, "loudest" is spelled "louest". There are too many errors to post here.
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Posted on May 07, 2009
Learn to read Chinenglish--the official language of the manual.
Posted on Feb 15, 2009
Can a longer cord be put on from the base to the handset ?
Posted on Jun 02, 2008
SOURCE:
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Lands Phones
My phone dials like a rotery not a pulse and is driving me crazy. Please help:)
You don't say what brand and model phone you have so I couldn't look for any detailed information, but somewhere on the phone will be a "tone/pulse" switch. Just where to find it I can't tell you so you'll have to play hide-and-seek.
For corded phones, check the bottom or side of the base part. If the phone has a spot where you can write your phone number, the switch may be hiding behind the paper strip under the clear plastic cover strip. If your phone has memory dialing, the T/P switch may be hidden under the card where you can write the stored numbers. On Trimline-style phones with the dial in the handset, the switch may be on the handset. On newer phones with setup menus there may be a tone/pulse selection setting instead of a switch. On wall phones you may need to take the phone off its mounting bracket to check for the switch.
On cordless phones, the switch might be on the handset or the base, again possibly hidden. Or it may be a setup menu choice again. But somewhere you will find a way to choose which dialing to use. Once you've found it, pick "tone" dialing and you'll be set.
Feb 25, 2011 | Lands Phones
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Ge 5.8 mghz cordless phone brand new
I have the same problem with a 25932 phone, and the instructions packaged with my unit was for the 25922 series. How serious are these people?
If you do get a solution, would you kindly e-mail it to my hotmail at [email protected].
Thank you so much!
Dec 26, 2007 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Thomson 26943GE1 Cordless Expansion Handset Logo
614 people viewed this question
Top Thomson Lands Phones Experts
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
