Question about Canon imageRUNNER C3220 Color Copier
Error code E000002-00007
Canon tells me turn off main switch and turn back on again. Gives me this code. Earlier we were having paper jam issues and I have since replaced the fuser because it was toast, but it still will not let me back into the printer.
  • Canon Expert
  • 287 Answers
Hello texantea,
Interesting, you had a fuser handy. That is exceptional. I wish I had a key operator as handy as you. Now to the point. Since you had a fuser code you will need to go into service mode to reset this error. I know the copier said turn off and turn on and blah blah. I have no idea why they do that when its a known fact that a fuser code(for safety reasons) cannot be reset by the customer. However if you go into service mode, typically used by us toner monkeys, the code can be reset. Here is what you need to do. Press "additional fonctions" on the op panel then press both numbers 2&8 at the same time and then press additional functions again.You will see a new and wonderful screen called service mode. The topblock of several will say copier. Press copier. At the top will be several tabs and one will say "FUNCTION". Press it. At about the center of the screen you will see "CLEAR". Press clear. Now you will see a menu which includes "ERR". Press err and then in the lower right corner press "OK". This will indeed reset the copier and allow the device to forget its past problems and take a fresh look at the start-up process. Once you have pressed ERR and then "OK".... power the copier off by the power switch located at the far rear portion of the right panel. Power it back up in a few seconds and if the new fuser you put in is good, you will be back in copier heaven.TADA!!!! Good Job! Please be sure to return to "FIXYA" and let them know I helped you , or cuss me like a dog. Either way I truly hope this helps. Take care!!!! :-)
Posted on Mar 25, 2008
Thanks for sharing some great info, spinal! Much appreciated!
Posted on Jun 30, 2008
Machine says paper jam and to remove paper No paper in machine Cant clear error codes
Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
or
Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
or
How To Reset Canon Printer MP160, MP180, MP460
How to correct, fix: Reseat ink cartridge for Printer (MP160 / MP180 / MP460) Issue: ERROR LED: E, 1, 4
How to correct, fix: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer. Wait approximately ten seconds and then press the <ON/OFF> button again. Wait until the device has completed its cycling process before submitting another job request.
Turn the machine off, and remove the power cord from the electrical outlet. Wait approximately ten minutes then plug in the power cord and turn the machine on. If the problem is not resolved, the machine may require service.
It just may be that the so-called roller cleaning operation may calibrate the timing
Jul 23, 2015 | Canon PIXMA MP160 All-In-One InkJet...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Paper jam problem
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
Jul 20, 2010 | Canon imageRUNNER 1370F Grayscale Copier
Canon mp600 printer repeated error code 6B00
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape. Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard. Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
Nov 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper Jam Error
Just clean and observe yaar , I dont have more knowledge , In my knowledge i am telling , just clean your printer and see yaar ,
Aug 28, 2007 | Canon PIXMA iP1600 Printer
Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Mar 16, 2007 | Canon BubbleJet i560 InkJet Printer
Canon imageRUNNER C3220 Color Copier Logo
219 people viewed this question
old marine
old marine
