Question about Lowrance GPS
Lowrance X91 Sonar Temp Reading
My X91 Lowrance Sonar does not show temperature readings. Temperatures were displayed for a few months of service over two boating seasons after the unit was initially installed (until the warranty ran out), and then the display read zero. After a few resets of the unit per instructions from Lowrance the temp function reappeared for a short while, but then reverted to zero again and did not return despite numerous resets. I sent the unit to Lowrance for repair and it was returned with a new temp sensing transducer, which I installed. I had the same results - a short period of functioning followed by no function, multiple resets, sudden recovery and then lost function after a couple hours service. The transducer is installed exactly in accordance with Lowrance instructions and is kept perfectly clean. I hesitate to send the unit back to Lowrance because of the cost. I would rather spend my $100 on a replacement sonar. Any ideas?
4 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: The sonar component occasionally looses
First of all, here is the main ONLINE SUPPORT page for your model :
http://www.lowrance.com/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-25C/
And here is a direct link to the ONLINE USER"S MANUAL for that model:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-110C_LCX111CHD_LCX-25C_LCX-26CHD0151-311_030705.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the icontents of the Ownwer's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 12 of the ONLINE USER'S MANUAL for detailed instructions on what angle you should set your transducer in order to prevent losing track of the bottom at high speeds.
Please comment back here to this page if you have questions or require further assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Good luck and thank you very much.
Joe.
Posted on Feb 19, 2011
SOURCE: LCX-25C seems to be cycling on & off when in the sonar mode.
I have a lcx-25 from year 2007 with same kind of problem. Service found o lot of condensed water inside. These devices are not water or gas proof. There was oxidized connectors etc. Maybe local electronic mechanic could help you.
Posted on Aug 11, 2011
mc1bean
  • 3053 Answers
SOURCE: Depth and speed are reading accurately however the
My name is Mike. I understand your problem. What I am doing to help you the best I can, is giving you the manual to download in PDF as well as a support number and other information to help you out. Also giving you my direct page to my Services I offer. Thanks SO Much , Mike.
http://store.humminbird.com/media/document/587_597_HD_DI_Manual.pdf
http://store.humminbird.com/products/399598/587ci_HD_Combo
MY PERSONAL MARKET PLACE SERVICES I OFFER
http://beta.fixya.com/users/mc1beanThank You, Again. Please rate my solution for my free help and some nice comments back would be grateful. God Bless, Mike
Posted on Oct 22, 2011
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
Somehow I have split the screen into two pictures of the same sonar reading. How do I get it back to only being shown on the one screen instead of being split into two.
Hi, press pages, then use the arrow up key to select sonar only page(it will show in upper left of screen the page you have selected.) Then press enter. Hope this helps, regards Phil.
Jul 20, 2011 | Lowrance HDS 5x Fishfinders HDS 5x...
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Sonar only reading the surface
First, ensure that the transducer face is pointing down when the boat is level in flat water. You may want to do this step like a tv antenna, adjusting the angle of the transducer while watching the screen.
If that doesn't work, then try moving the transducer further into the water and repeat step one.
Sonar systems are (largely) directional, and will work best when parallel with the seabed (or lake bed etc)
Jan 20, 2018 | Lowrance LCX-104C
Proper set up for lowrance sonar
Where do you use your boat?
There are so many variables it's hard to fit it all here, but there are some excellent tutorials on the Lowrance website. The most important thing is to pick the right frequency, for the depth of the water. (200khz for less than 70', and 50 khz for greater depths). Depending on how serious you are about fishing, there are a lot of extras that you may never use. The key is to figure out which features will help you the most and forget about the rest.
You may also get some help at this link: FixYa Service Directory
It's common for SONAR to lose contact with the bottom at high speeds. The better the transducer installation, the faster you can go. Turbulence and bubbles will cause the SONAR to drop out. Lowrance's transducer installation guide explains it very clearly.
Jan 03, 2009 | Boating
GPS Logo
211 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
