Question about GE WSXH208A Front Load Washer
Dishwasher makes loud pulsating noise. We think it is the lower spray arm. It does not turn evenly. WE would like to remove and reseat thisarm. Model #GSD6900JCC.
  • goldengirl82 Mar 30, 2008
    yes same loud problem how do you fix this?
  • 487 Answers
Posted on Apr 15, 2008
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
Frigidaire 18" dishwasher arm is not spinning, and dishwasher is making a very loud noise.
Hi Ellie, this is AP!
I understand you are experiencing some trouble with your Frigidaire built-in dishwasher. Without knowing the exact model number I would assume there are two spray arms on this dishwasher, are both arms not moving or just one? Keep in mind that some dishwashers have two spray arms that turn at alternate times. They will never move at the same time. The changing of the arms starts at different times depending model and will continue through the end of the selected wash cycle.
If you can provide the model number for the dishwasher I should be able to provide you with the instructions to remove the spray arms or you could contact the manufacture they may supply it to you also. You could also apply rinse aid to the junction between the spray arms and mount to see if it will relieve the arm to spin. If not, please reply back with the model number so I could provide a more educated response.
Best Wishes,
Mar 30, 2014 | Frigidaire 18" Built-In Dishwasher
Dishwash is making a very loud noise - what to do
Most noises come from debris caught in the sump/ impeller area. Don't know your brand but if you can remove your lower spray arm there are probably some screws you can see and remove. Just keep removing parts till you get into the impeller area. Or it could be the motor itself making the noise.
Oct 20, 2011 | KitchenAid Dishwashers
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
Abnormal Dishwasher Clicking noise
Try spinning each of the spray arms in turn and in both directions to see if the noise is related to an arm or it's bearing. You might have to disassemble the lower spray arm mechanism to the deck to inspect the recirculating pump impeller for anything that might have gotten pulled into the impeller. That pretty well covers anything that rotates in the machine except for the motor itself. Hope this helps!
Mar 13, 2010 | Maytag MDB3100 Dishwasher
Dishwasher - excessive noise from lower spray arm.
Remove the spray arm (just pull it out) and clean the "seat" with soap and a nylon bruch and se if the problem continues.
Mar 14, 2009 | GE 24 in. Profile PDW7800 Built-in...
Noise when spraying
The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
Feb 05, 2009 | GE 24 in. GSD2030Z Built-in Dishwasher
Noise from dishwasher
Dishwasher makes loud noise in begining. How do I remove lower spray arm to see if something is stuck? Whirlpool DU1055xtpb4.
Jan 14, 2009 | Whirlpool Dishwashers
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Loud Knocking/Ticking Sound During Cycle
have you lowered the top basket into the lower position? if so the spray arm will knock the cutlery /plates. it sounds as though it is a spray arm problem. remove them and put it in wash to see if the noise goes. if not there may be an obstruction in the wash pump, this is a stripdown job then.
Jun 04, 2007 | KitchenAid KUDC02IRB Dishwasher
GE WSXH208A Front Load Washer Logo
183 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
