Question about Acer Aspire 3680 Laptop
My laptop it having more problems...
When I plug in some speakers to my laptop, everything works fine for about 4 hours, and then out of nowhere the speakers just stop working. When I unplug them, th internal speakers work just fine. It's starting to get real frustrating, I tried every other speaker I can find, including headphones, but they still won't play for about 5 more hours, then after that they stop again >.<
  • 3 more comments
  • dustyn333 Mar 19, 2008
    Okay I just screwed something up... I was trying to fix the sound, and I went in there and accidentally disabled my laptop internal speakers. It says sound is coming into this other kinda speaker, but nothing comes out, so the only way I can listen to sound on my laptop now is US headsets...
    k never mind fixed that >.<
  • jogratziano Mar 24, 2008
    My external speakers plugged into my Aspire 3680 also will sometimes not work and sometimes work again after being turned off for a day. Did the stuff like un-installed and reinstalled the driver etc. and followed the suggestions at http://forum.notebookreview.com/showthre... and
    http://www.rm.com/Support/TechnicalA...e...
    Someone suggested an external sound card, which I'm contemplating.
  • Bob Santos Apr 09, 2008
    my acer 3683 laptop's speaker line out is no longer funtioning...
    before. it is working, but as the days go by, it becomes worst... and i don't even know why it has happened an i don't even know what to do with this problem.
  • Russell Stewart
    Russell Stewart May 11, 2010
    This sounds like a heat issue. After a few hours, some connection is expanding and severing the output. The break will be on the circuit board or on the leads going to the audio output.
    If it is heat related, not something you can fix without opening the case (and learning to solder).
    Genius:
  • 3,587 Answers
Sounds like a simple example of overheating on the laptop. Do you have it up off the surface, so that the air can get into the bottom or back fan?
Posted on Apr 21, 2008
Toughbook CF-53 Speakers won't work
Have you tried rebooting? In the Control Panel, select Sounds, select Speakers as default, remove headphones plug from jack.
May 24, 2013 | Computers & Internet
My truck turns on, idles fine but when i give it gas it only goes about 3 mph. when i want to excellerate it goes nowhere
Not quite everything is fine.
Is the check engine light on ?
When you push on the gas pedal, does the engine speed change ?
Can you rev up the engine in park ?
What have you checked so far ?
Jan 15, 2013 | 1993 Nissan Pickup
Speakers are not working
try these. remove ac adapter and battery. press and hold on the power button for 15 seconds. plug back ac adapter and battery. download the latest bios for your system from the manufacturer's website. if still same problem try a system restore from the time when everything was working fine. try an external speakers check if the audio jacks are working. if all fails replace mobo. if external speakers ok then replace laptop internal speakers.
Apr 03, 2010 | Computers & Internet
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Headphones: only left speaker works
yes if you have a multimiter and a soler iron, just check the cable where is moving allot, for example for the headphones near the volume controler, near connector or near you eyers is more likely to brake
Aug 20, 2009 | Audio Players & Recorders
Sony vaio audio driver problem
if not anything open the system and check the connections sounds like you have hit on everything else besides that
Jul 21, 2009 | Sony VAIO VGN-FS840/W Notebook
I got new speakers for my laptop, and they don't work!
go to the control pannel, then go to sounds and audio devices, then click the audio tab across the top. under sound playback, choose your speakers as the default device. solution only works like this for windows xp. good luck
Apr 29, 2009 | Ozaki DT-500 3-Piece Speaker System...
USB Audio Device Drive Load Failure
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Dec 21, 2008 | Logitech V20 Computer Speakers
Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Nov 02, 2008 | Audio Players & Recorders
Acer Aspire 3680 Laptop Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
