I have a Canon MP830 printer.For no apparent reason I am getting horizontal blank gaps 1/4" wide and about 19/32 between gaps.I have utilized all the maintenance steps but still no luck
  • 3 more comments
  • 2suejoe Mar 20, 2008
    I am getting gaps of printing uniformly from my MP380
  • 2suejoe Mar 22, 2008
    Yes,The black prints fine.The color is faded and only half of the color lines seem to print at least the letters in thetest pages.
  • 2suejoe Mar 29, 2008
    I have a Canon MP830. The horizontal lines print fine . I ran continuious lines horizontally down an 8 1/2 x 11 page.The lines are 1/4 inch apart. however the first 3 print fine.The fourth line is totally blank..Then 3 more lines print fine but again a blank space and on with regularity.
    Any particular cartridge .I have 2 blacks and three colored.
    Is the service manual you speak of the same as the users guide? I think not but don't want to spend 9.99 if there is duplication.
  • 655 Answers
Your cartridge seems to jam due to dry ink. Some of the nozzle is jamed and ink not passing through it. As a result you are getting blank line.
If all the privious solutions have been failed, then try this:
1. Remove your cartridge from printer.
2. See care fully on the bottom of the cartridge.
3. Take fresh and clean paper, (out of dust).
4. Clean it manually and gently.
5. Clean it till some ink deposited on the paper.
6. Then place the cartridge gently at the positions in the printer
and enjoy happy hours of printing.........:))
And don't forget to Rate This solution as Fixya.........lol
Thanks
Iqbal
Posted on Mar 29, 2008
  • 3,037 Answers
Have you tried to clean the printer heads, I would try shaking the color ink cartridge and clean the head and if you tested the ink flow from the cartridge it should be a solid line
the printer heads would be my best bet on this problem or possibly some of the metal readers got dirty that transfer the printing information. You could try cleaning these, they should be a thin piece of metal next to the printer heads and ink cartridges
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    since the colored are having problems, those are the only ones that you need to work on
  • Benjamin Patri
    A service manual and a user guide are usually two different things, but it might be easier to take it to a printer repair shop than buying the service manual if you can't figure out how to fix it
    Genius:
  • 1,665 Answers
I think you need a service manual ; it is below:
http://www.2manuals.com/product_info.php?products_id=684
but first try to update printer's driver or uninstall and install again and see if there are changes in printing.
Posted on Mar 20, 2008
    President:
  • 1,950 Answers
Are you using original ink cartridges?
    Guru:
  • 1,894 Answers
Can you brief about the steps you have used til now sir?
Posted on Mar 19, 2008
  • 2 more comments
  • dewan nafees ahmed Mar 19, 2008
    so that we can give you new solutions to try with.
    here is a lot detailed explanation.
    please patiently go trough all.
    Horizontal or Vertical gaps in the printing?
    If you've just recently replaced a cartridge and the printed page is
    entirely blank, contains blank gaps or missing text:
    1) Make sure you've removed the protective shipping tape or vent
    tape.
    a) This is easily overlooked but is quite simple to remedy.
    On HP, Lexmark, Dell and similar disposable print head cartridges,
    you'll find a strip of plastic film on the bottom of the cartridge
    covering the printhead. This tape is used to seal and protect the
    printhead during shipping. It prevents ink from entering the
    printhead where it dries to form an ink clog.
    *WARNING: DO NOT CONFUSE
    SHIPPING TAPE WITH THE CONTROL RIBBON, The red-brown film which
    contains fine circuitry used to operate the cartridge. Removing the
    control ribbon will render your cartridge useless.
    b) On Epson, Canon and Brother cartridges, for fixed print head
    inkjet printers, you'll see a tear off strip, usually with a graphic
    which indicates that the tag is to be pulled. The tear off strip
    seals the the vent holes on the top of the cartridge to prevent it
    from drying out on the shelf or during shipping.
    After ensuring that the shipping tape has been removed, run the
    printer's "Head Cleaning" utility to prime the cartridge, then print
    a test page.
    2) If your printed output still indicates clogged ink nozzles:
    1. From inside a software application such as MS Word or Notepad,
      go to the File menu and click "Print".
    2. Click on your printer in the list to select it.
    3. Click on the "Preferences" button and the "Utilities" or
      "Maintenance" tab
    4. Locate and run the "Head Cleaning" utility at lease once but no
      more than 3 times consecutively.
    5. Print a test page.
    *WARNING: If your
    cartridge houses your print head as in HP and Lexmark inkjet printers,
    never use the Head Cleaning utility more than 3 times consecutively!
    You'll likely burn out the resistors in the cartridge's print
    head. Wait 20 minutes while the print head cools before trying again.
    Check your printer manual and documentation for recommended methods.
    Since most Epson and Canon printers use suction pumps to clear
    clogged print heads, repeatedly running the cleaning cycle applies
    increased suction to the clogged print heads. This tends to waste a
    great deal of ink and in most cases, probably won't damage the print
    heads. Check your printer manual and documentation for recommended
    methods.
    Wait a minute or two to let the ink soften and liquify between
    cleaning cycles. Always print a "Nozzle Check" or "Test Page" between
    cleaning cycles. Check the test pattern to ensure that all nozzles are
    firing. If not, wait a few minutes before trying again.
    TIP: Print several (two or three)
    pages of a full spectrum color image
    (to remove air bubbles or foam that a printhead cleaning cycle may not
    have removed). If the printed image is still not acceptable, repeat the
    process.
    To clean ink cartridges with print heads:
    1. Take a shallow dish and pour in the liquid to a depth of 3 to
      6mm (1/8 to 1/4"). You should have just enough to wet the print
      head.
    2. Remove the problem cartridge from your printer. Avoid touching
      the print head or contact ribbon and place it with the print head in
      the liquid. Let it soak. Depending on the degree of blockage, this
      process can take anywhere from 10 minutes to overnight.
    3. This process does require patience, so just let the cartridge
      sit. Refrain from tapping it or rubbing the print head. In doing so,
      you may just drive the clog back into the print head. You'll know
      it's working when the colour you've been having problems with starts
      to flow into the surrounding cleaning liquid.
    4. Take a few sheets of paper towel, fold them into a pad and pour
      some cleaning fluid into the center. The towel need not be
      completely soaked, but the center should be quite wet.
    5. Remove the cartridge and holding it gently by the sides, be
      careful not to touch the electrode ribbon and gently push it down
      into the center of the moistened paper towel. Rock the cartridge
      gently from side to side, front to back in a dabbing action in order
      to draw the clog out and get the ink flowing more freely.
    6. You should see the colour spotting on the paper towel. Once
      you've established that the ink is flowing, reinstall the cartridge
      and, try another head cleaning and print a few more test prints.
SOURCE:
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
There are horizontal white lines in graphics Cannon MP830 Printer
This sounds to me like you may want to upgrade the firmware also, If your ok following instructions then this should be a breeze...
heres the link to get your firmware:
click here to get your firmware
hope this helps you out and if so please mark fixya...
Jul 03, 2010 | Canon Office Equipment & Supplies
Canon mp830 prints blank pages.
Did you find a solution? I'm having the same problem.
Apr 13, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP 830 gaps in printing
Uninstall the printer driver completely, then reinstall the driver again.
Aug 06, 2017 | Canon PIXMA MP830 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Vertical line on page
i have the same problem although its a horizontal line
Jun 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My Canon MP830 suddenly refuses to print black. The tanks are apparently full or nearly so, and I have used deep cleaning utility several times to no avail. It refuses to print at all. This happened all at...
drivers...can really get corrupted for no reason, or a good reason(power glitches)..so..reload the drivers/print management software, remove the printer from the panel, unplug it from the computer, then reverse that. Should 'see' it, and you may be back in business soon.
Got backup?
Feb 10, 2008 | Canon MP830 All-In-One Printer
CANON MP830 PRINTER
Had the same problem - apparently a certain batch of these printer have a fault with the mainboard - mine was replaced under warranty and now the problem is solved.
Feb 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Computers & Internet Logo
144 people viewed this question
Ekse
Alun Cox
