Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Flickering blue screen problem
Hi Neals!
I wanted to thank you for your solution post. It has been utmost valuable to me. We already spent $75 for some doofus repair man to come look at the tv, and he didnt even open it up!! He decided the tuner was busted and that would cost some $1k to fix. (mind you, he didnt sell new tv's)
So with your post, and lovely pictures, we opened up the tv and found that we had the same problem. We could only get to the power board, the other 2 boards were WAY too difficult to unplug and get to... though we did get a sideways look at the caps and they *seemed* ok.
The circuit board is now at the shop to be soldered because we dont have that skill.......... Hopefully that fixes the problem since it fixed yours!
    Problem Solver:
  • 6 Answers
Glad it was helpful! I had researched quite a bit before I started and realized there was a real lack of detailed info for the wdx2x25 models so I figured I would take some photos and post while I was at it.
If fixing the PWR board doesn't do the trick, getting the other two out is not as bad as you might think - just tedius. The V26 Chassis Replacment manual (different than the main service manual) has reasonablely detailed step by step instructions to disassemble. Let me know if you need it and I can email.
Posted on Mar 20, 2008
I bought 4 ZEEPAD 7DRK Rock tablets for my grand kids for Christmas and 2 of them will not even turn on. The 3rd one worked for 3 days and it also will no longer turn on. I've tried charging them...
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
Jan 01, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
Acer aspire 5515 blue screen
hi
yes it may be related to bios setting . Just enter your bios in the laptop (F2)
and for HD change the SATA to ATA or vice-versa. SAVE and retry boot.
(it can also be AHCI to ATA or ATA to AHCI.)
Aug 12, 2012 | Acer Computers & Internet
Laptop screen suddenly starts flickering with warious color bars
If your lcd screen got harizotal line ( Pink, blue or red ) and flickering, that means your lcd ribbon or board on back top was crack or faulty I believe your lcd screen model is LG Display. There are not have any way to repair it. You must be replace with another lcd but I suggest you to change it with Samsung brand lcd screen. You can buy new lcd screen from ebay.com
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Toshiba Computers & Internet
SONY MODEL: DSC W110 - SCREEN IS POSTING BLACK SCREEN
hi other than black screen work fine? you might has back light problem or main pcb. either way your local repair shop would charge $45 to 75 depend on what they really want to charge. Thanks and best regard!
May 22, 2011 | VuPoint DV-M5056-VP Digital Camera
Hi I got a problem with my gateway laptop hope you could help me ?
if you have a blue screen on the start up you will need to use the windows cd to fix the installation. do a repair install, don't go into repair console when asked simply continue the setup and when it finds your windows installed select to repair the installation.
Dec 27, 2008 | Gateway MX6453 Notebook
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Cloudy TV Screen
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Flickering blue picture
I finally got around to dismantling the TV. This is no mean task. The chassis is tethered to the rest of the set my over a dozen wiring harnesses and a few of these cannot be disconnected near the chassis but instead require removing the “right support” near the air duct and taking the shield off the lamp ballast. Once the chassis assembly is out, it is a further significant task to disassemble it to get at the various PWBs (POWER, FMT and DM) having the suspect caps. I’m sure reassembling everything will be a fun job!
I have not yet had a chance to fix and reassemble but I wanted to post this no as I’m not sure when I will get around to it.
I did find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Jun 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
Oct 24, 2006 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
