Question about Iomega (33090) 250 GB Hard Drive
Hard Drive won't read or even show on the computer
I looked for the controler software on the net to no avail
    Scholar:
  • 74 Answers
Hiya Samaxwell
What O.S are you running? spec etc... Are you fitting .. just fitted.. or was it fitted in the machine to start with?
Regards Faggly
Posted on Mar 19, 2008
SOURCE:
Can I get a cd to load my camera onto my computer...I cannot fine mine...
Not sure what software you need from the CD, but here is a link to Canon and there is some software available for download for your camera that may solve your problem.
Canon PowerShot SX20 IS
Dec 04, 2015 | Canon Powershot Sx20 Is - 12.1 Mp - 20x...
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
My laptop can detect my hard drive but i cant access the files in it
you can recover files from hard drive with asoftech data recovery program. download the program from
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 27, 2011 | Computers & Internet
I transferred a 40gb hard drive onto this 250gb go flex drive and then transferred it back. Now when I try to tranfer anything else to this drive, it only allows 40gb of space to transfer. I reformatted...
my computer does not read or detect my hard drive no matter what i do, and when it does read from the drive it does not upload to the computer. so what shall i do?
Jan 25, 2011 | Seagate O 250Gb Usb20 Freeagent Go Silver...
I don't have the software to download onto my new laptop it is on my own main computer but not my laptop so I can't download pics onto my computer from my camera. I was wondering how do I do that? If you...
windows doesn't always need software to read pics from a camera.
Just connect the camera, and have a look in 'My computer' you may find the camera's memory shows up as hard drive... worth a try.
Alternatively, remove the memory from the camera and either plug it straight into the laptop (and look in 'my computer') if you have the correct slot, or connect it via a cheap $2 memory reader (available from ebay).
Jul 13, 2010 | Computers & Internet
Unistalled ext hd unsafely, now not being recognized.
It could be that the "table of contents" on the external disk-drive has been scrambled. Whatever you _do_ try, do _NOT_ try to run 'CHKDSK' (or "check disk") against the drive.
Instead, look online for "File Scavenger" software, which can read through the drive, sector by sector, and try to "stitch" together the pieces, in order to "recover" your files.
Jul 03, 2010 | Western Digital My Book Home Edition 500...
Problem in hard disk
control panel
computer management
disk management
select the disk and iniatlize by right clicking.
Jul 09, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Sandisk Cruzer Micro lights up but won't read
I would say it's DOA. These thing don't seem to have a very long life span, even though I have the exact same one but I'm expecting it to go out at any time. I had a 128mb that bit the dust the same as yours. But try those free data recovery software on the net you may get lucky???
Nov 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim 4gb
please use the CD came with the drive and formate it full. Reconfigure everything so that it will show the patition that you want in the window. Do not worry 'bout the Data. you can recover all by using data recovery software available on the net. Try google serch.
Oct 09, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
Top Iomega Computers & Internet Experts
Ekse
Marvin
Marvin
Gustavo Ortiz
Gustavo Ortiz
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
