FixYa.com
Tags:
Denon DHT500SD System
Can anyone help to explain why?
posted by jane717 on Mar 19, 2008
Dear Abrsvcs, Thank you very much for your help. My amplifier is made of Denon, and the model is: PMA350. It has been working very well for me but when I tried to turn on the music it suddenly had no sound.
I checked around briefly but nothing seemed wrong. Would you be able to provide me some instructions that I can try to fix the problem?
Many thanks.
Cheers
Jane
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 19, 2008
Helpful (85)
Abrsvcs
Rank:Guru Guru
Rating: 85%, 515 votes
The output section has a problem and the amp is in "protect" mode. This will most likely require the replacing of the output transistors and a few other parts. Figure about $20 in parts plus your local labor charge.
Dan
Rating Locked! (?) jane717 has rated this solution as Helpful
Can you Help with these Home Theater Systems problems?
Denon adv-500sd will not play...
Hi I have a DENON ADV-500 SD... Answer This...
DvD wont load discs
Its been fine up to this week... Answer This...
Switching between functions and...
My DHT500SD has suddenly... Answer This...
Denon 500SD
Power light is on but it is... Answer This...
Auto-switch off
Hi, When we switch on the... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
