Question about Motorola Mobility RAZR V3
Razr Inop After completing phone call I flipped phone closed and noticed bluetooth indicator illuminated (I don't use bluetooth function at all). Opened phone back up and screen was dark. Was able to make a phone call, but could not receive. Battery is/was fully charged. Outside of phone also got very hot. Have removed and re-installed battery, but phone is now completely inop. This is a new phone (1 month old) and has not been subjected to any abuse. I bought a neoprene cover for it to ensure it was kept in good shape. Any idea why my Razr may have self-destructed?
  • Thuleman Mar 31, 2008
    That's what I did. Of course ATT will only replace with a refurbished one. Thanks.
    Brigadier General:
  • 7,752 Answers
You need to take the phone back and have it replaced for a new one.
Posted on Mar 30, 2008
What does it mean when my iphone4s states that Bluetooth it's now discoverable as iphone
Hello Bernard Baudry,
It only means that you Bluetooth is
"on" and capable of functioning... (you should see the
ICOM immediately to the left of your battery bar...
top right side of your logon screen.
Perfectly safe...
You can not be joined unless you PERMIT IT.
If it bothers you ... 2 EASY WAYS to turn it "OFF".
(or on) in your iPhone "4S" is quite simple ...
Same as using the "flash-light"
feature (and on the same page)...
Simply press the "menu" button... flip up your menu
by quickly moving the grey dash at the bottom of your logon screen... (up).
You will see (center top)... the illuminated
- Touch it once (OFF = (not illuminated))
- Touch it again... Illuminates (back on).
ELSE... you can logon to your phone... get into "settings"
and shut it off there... (no reason to do so... unless you are
never planning to use hands-free (more new laws
(your phone may be "paired" to many legal devices)).
You'll be safe and able to respond to EMERGENCIES...
>> IOS 9.3.5 (as high as we "4S" folks can go).
Carnac the Magnificent
Jan 04, 2017 | Cell Phones
How do a enable bluetooth?
A lot of times there is an additional switch to turn on bluetooth. If you don't see the bluetooth logo illuminated blue on your laptop then it's probably not on. Look around for it. It also may be a function key. Ie hold the function key and hit the F key associated with bluetooth. you can see the logo here
Oct 22, 2012 | ASUS Eee PC 1000H Laptop
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
When not in use, the phone continues to stay illuminated, like when it's flipped open. It draws down the battery within 1 day. Any suggestions? It seems like it might be a switch not being activated when...
go through your menu options to display settings. there should be a BACKLIGHT option which should allow you to select a a lesser amount of time that the phone stays lit.
Mar 22, 2010 | Motorola Mobility RAZR V3
Does not conect to cell phone What is the
First fully charge bluetooth.close bluetooth flip/turn on power by press button in the midle and open flip look blue light not flashing ok for pairing.if not do again and again,pairing only light stay on no flashing.
In phone go to bluetooth function/bluetooth turn on/searching devider ok/enter 4 zero ok.sucessful for pairing.
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
The flip top the razr completely broke off.
yes, Depeding on where you are, its probabely cheaper at a repair store than sending back to Motorola for repair. You probably need at least 3 parts. The bottom honged part that holds the keypad. Plus the main flex cable and the chrome hinge. However If you are not experined with this, it will be kind of hard for you to repair
May 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Screen Blanks, Phone Turns Off Sporadically
Looks like a battery problem. You might want to replace it.
Sep 05, 2007 | Motorola Mobility RAZR V3
Bluetooth indicator light
just try a master clear and reset of the phone.
Aug 13, 2007 | Motorola Mobility RAZR V3
Bluetooth headset
you need to turn on the headset and to order the phone to search for BT devices.
May 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
