Question about Sherwood RV-5050R Receiver
Remote codes for Sherwood RX4109
I am unable to program my Charter UR4EXP universal remote to a Sherwood RX4109 amplifier. Can you help?
When I enter the correct Sherwood RX4109 model, your web site says this is not a valid product! ??
  • Anonymous Feb 12, 2009
    i lost my remote and need a new one does anyone know where i can get a remote for sherwood RX4109
  • Anonymous May 11, 2010
    did you try codes 0706,0806,0858,0859 ?
SOURCE:
SOURCE: Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
Posted on Nov 18, 2008
  • 12 Answers
SOURCE: sherwood rd7103 rec.
no listing for Sherwood receiver. must do the remote "search" function. here is how:
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope that helps!
Posted on Mar 01, 2009
greenspan
  • 1734 Answers
SOURCE: looking for remote code for sherwood rx4105 to work with comcast
Ask the remote code experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    jdvillanueva
    • 2098 Answers
    SOURCE: need the 5digit code for the sherwood rx 4109
    Hi Woodyscarava,
    You may look the remote code in this link http://www.comcast.com/corporate/customers/customer_support/remotes.html. Select the model of your remote control and view the manual.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    Posted on Feb 16, 2011
    I have a zenith 5 device universal remote can i program it to opporate my RD-7500 Sherwood receiver. don't have original remote, what code can i try?
    0374
    This is the only one code, that I can find out to Sherwood TV. Anyway there might be more. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
    http://electro-medical.blogspot.com/
    http://remotesearch.blogspot.com/
    http://electrohelponline.blogspot.com/
    Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
    Irrespective of the brand name of the remote control, some other codes said for Sherwood TV might work.
    Sep 27, 2015 | Zenith Televison & Video
    Trying to program charter remote with bose cinemate home theatre speaker system. Does any one know the codes?
    Using Universal Electronics Charter Remote OCAP 4 Device, I was able to get the volume control to work using the final code in the code listing, 31933
    Aug 22, 2013 | Bose Cinemate Digital Home Theater System...
    I have a sherwood stereo receiver s-7100 I want to know how to connect speakers that have a rca typ plug to the receiver
    WHY? Speakers with RCA plugs are notoriously low-end and intended for specific same-box amplifiers.
    If you must: Make sure their impedance is at least 6-ohms. Lop off the connectors, strip the wires and boogie. Keep the fire extinguisher handy.
    Jul 04, 2011 | Sherwood RX4109 Remote Control Stereo...
    I need ptv k feed code on asia sat 3s
    the key is SID 0003 key C9 A6 4F BE 2B 5D 7A 02
    Mar 09, 2011 | Sherwood RX4109 Remote Control Stereo...
    Need codes to program universal remote for my Sherwood AV5050R home theatre
    dont have book how or what do i do to program my remote lost my book
    Jul 28, 2009 | RCA Universal Remote Control
    Unable to program Directv universal remote for tv
    The RC64RB has more codes in it. Unfortunately, it is an extra $25. BUT, it is backlit, which is very cool at night. With my RC64RB, I get 16 codes to enter for your TV (Emerson HDTV).
    Dec 29, 2008 | Universal Remote Control DIRECTV Universal...
    Using a Logitech Remote
    check the booklet it come with see if the named the book or go no the company web site
    Dec 22, 2007 | Audio Players & Recorders
    Sep 07, 2007 | Sherwood RD-6108 Receiver
    2,144 people viewed this question
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Don Hart
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
