Question about RCA D52W19 52" Rear Projection Television
D52w19 had a problem of turning it on green light would flash 3 times.then you had to wait 2 minites to do it again nothing would come on .ok i replaced 2200f 16v cap on power board.tv now comes on picture and sound.but the blue color flashes across the screen horizontal all the time.what could be the problem?
  • 1 more comment
  • bubba Mar 20, 2008
    set is may of 2004
    may 2004
    i was watching it a little tonight.if you watch the screen the picture looks like it is jumping out.like it gets one size larger then one size smaller along with the horizontal all the time .kinda hard to explain.and no its not the weekend.lol!
  • 24 Answers
How old is this TV?
Posted on Mar 19, 2008
  • Anonymous Mar 20, 2008
    I'm not sure on that. I pretty much deal only with DLP. If that were my tv having that issue. I'd call circuit city & say you bought a tv last year from them (rear projection) & describe the issue.Not going to be much different in a rear project today & 4 years ago. If you call the manufacturer, they will ask you for serial numbers and bunch of other **** before you ever speak to a tech support. Let me know what you find out.
6ya staff
SOURCE:
Green light then red/green light then flashing red
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation 3 back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
RCA d52w19 green LED flashing and speaker int/ext switch problem
The most probable cause are the Three capacitors CP150, CP114 and CP120 all located on the deflection board.
Dec 13, 2009 | RCA D52W19 52" Rear Projection Television
Problems powering up
These sets have alot of problems with poor solder connections resolder all pins on flyback transfomer, check 3 capacitors on power/deflection board cp(150) 2200uf 16v (cp120) 220uf 35v (cp114)220uf 35v they are green with gold writing.Also it is better to fix it Now because the longer you keep trying to play set it can cause more damage to it.
Dec 13, 2008 | RCA D52W19 52" Rear Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Tv will turn on
leadfoot,
i believe the problem is the flyback transformer. try cleaning by using a small aerosal can. this will either correct the problem or you might have to replace it.
flyback transformer stores energy so i would suggest hiring a professional technician.
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
