Question about Cameras
MiniDV camcorder. Hello I have a video camera question. I was showing my videos on the tv to my family. I powered off when we were done and the next day I went to view them again and the camera told me to reset it. I did that but everytime i tried to play the video it would say reset. So I looked into it and i was told that the camera was not going to work. So the next day I went and bought another MiniDV camcorder and tried viewing my video on that camera and it won't let me view any video on my new camera either. I have tried several different tapes that i know there is video on them. Can anyone help me out? Thanks
  • 4 more comments
  • lisagersh Mar 20, 2008
    I have used a Sony DCR-HC21, Panasonic pv-gs320, and also a dcr-hc52. My newest camera is the dcr-hc52. I have not even recorded anything on this camera i have just tried viewing my old videos on it. I'm kind of panicking because I have a lot of tapes and they will not view thru the camera or the TV. It was the panasonic that i was using when it said to reset and I did and it didn't fix the problem.
    I don't have any blank tapes at the moment. I had rewound the tapes that was in the camera so I didn't want to tape over anything. So could the camera be corrupting my tapes? If so are they lost forever? I haven't downloaded any of them. I've been using composite.
  • lisagersh Mar 21, 2008
    I went and bought some blank tapes last night. I tried recording on my new camera and it seems like it is recording but when I go to play it back there is nothing on the screen. The counter counts when I'm recording but when I go to play it back the counter just stays with lines on it.
    On my brand new camera I am now receiving a message that the heads need to be cleaned. How is that possible I just bought this camera two days ago and haven't even used it other than to try and view my old tapes. I did look in the manual and it does say that the camera is NTSC capable.
    Do you think my old video tapes are ruined? If they are making the heads of my video camera dirty does that mean my tapes are ruined?
    Thanks for your help. I did try and clean the camera with some compressed air. It did work and my old video is still there but after changing tapes I still had the same problem. So I would assume there is dirt on the tapes. My local store did not have a head cleaner so I will have to order one online. Thank you again for your help.
    Brigadier General:
  • 6,966 Answers
Pls, can you post back on the specific brand and model of the MiniDV camcorder. Additionally, could you add info what camera(s) were used to record "several different tapes that i know there is video on"
This is of course not a solution but a request for more information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 20, 2008
  • 3 more comments
  • Louie  Role
    Louie Role Mar 20, 2008
    Sorry The Machine to have doubled up. Guess you posted while I was composing. Cheers.
  • Louie  Role
    Louie Role Mar 21, 2008
    Hi again,
    and with the indulgence of The Machine,
    I don't think any of your previous tapes were erased.
    However, to my knowledge your new Sony DCRHC52 Mini DV Handycam is a PAL only, whereas the Sony DCR-HC21 and Panasonic PV-GS320 MiniDV Camcorders were both PAL/NTSC capable.
    That being the case, it is very probable that all your previous tapes were recorded using the NTSC mode (which is the standard in US). This of course will not play in a PAL only device (such as the new Sony DCRHC52). The PAL standard is commonly used in Europe and Australia.
    Corrective procedure would call for the use of a NTSC/PAL MiniDV Camcorder or at the very least an NTSC one.
    Additionally, should you be going this route (replacing with an NTSC capable MiniDV Camcorder), may I suggest that you pls bring along one of your old tapes to verify playback capability.
  • Louie  Role
    Appreciate the additional information.
    There is of course the possibility that it is just might be that, dirty video heads. If you used the camera to rewind the old tapes, then possibly, dirt and other foreign materials might have transferred from the old tapes to the video of the new camera.
    Am not sure if tape head cleaner of the size are available in your area but what could be done is to manually clean the video heads. Manual cleaning involves the use of a clean strip of paper held against the video head while the head is rotated manually. Please see http://www.studiosoundelectronics.com/vc..." target="_blank" rel="nofollow" >image below.
    Of course, it would rather be a tight squeeze since the camera is small. You can probably figure out a way to do this without removing the casing/cover.
    Alternately, you can try a long reach cotton buds to clean the actual heads which would be small indentations with a thin lip somewhere along the rotating drum. Additionally, a can of low pressure compressed air could also do the job.
  • Louie  Role
    No, maybe a bit moldy, dusty or something like that but they do last longer. To prevent future incidence of the same, perhaps you can purchase a simple tape rewinder appropriate to the size of your tapes. If you did purchase the can of compressed air, the same can be applied to the inside of the tapes to clean them as well.
  • Louie  Role
    Louie Role Mar 22, 2008
    You are more than welcome. Glad to be of assistance.
    Would appreciate if you can rate the solution offered as how you see it fit.
    Thank you too.
    Master:
  • 788 Answers
Have you tried recording new video to a new tape and trying to play it? Your old tapes could have become corrupt.
What brand/model of camera do you have? What type of connection are you using to the TV? Composite or S-Video?
Thanks.
  • Dean Joly
    Dean Joly Mar 25, 2008
    The NTSC/PAL mixup does make a lot of sense. Not sure how things are panning out in Europe but if you live there you should stick to PAL and if you are in North America you should stick to NTSC.
    It also makes sense that the heads were dirty in your old camera but is very odd that your new camera is reporting dirty heads. I would have your dealer replace it if you are concerned.
6ya staff
SOURCE:
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
When I playback my videos, the picture is obscured by a series of thick black lines
Hello
Just to clarify, does the footage look something like THIS?
If this is what you are experiencing, it is a result of "Dirty" heads.
If you have a head cleaning tape, run this through as per instructions.
If you don't have one, buy one.
This should fix it.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Jun 24, 2010 | Panasonic NV-GS11gc Mini DV Digital...
Looking for a manual for my PV-GS31 minidv digital camcorder
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Operating-Instructions/model.PV-GS9.O#ts
Jan 05, 2010 | Panasonic PV-GS31 Mini DV Digital...
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
How do you put video from your camcorder to your computer?
With a Canon ZR70MC camcorder, you can record video onto miniDV tape, or onto the SDmemory card in Card Camera mode.
To access video on the miniDV tape, you will use the DV cable (IEEE 1394 aka FireWire). Connecting this cable to your windows computer will allow you to transfer high quality video using the software supplied on the digital video solutions disc, or just about any other windows video editing software.
To access videos stored on the SD memory card, remove the card and place it in a card reader connected to your computer, or attach a usb cord to the camera and the computer. Video stored on the memory card is limited to 10 second clips @ 320x240 resolution.
Oct 11, 2009 | Canon ZR70MC Mini DV Digital Camcorder
How to transfer videos from samsung vp-w70 to pc or watch via tv
Did your camcorder not come with a cable to connect to the TV?
If not, I had the same issue last year wanting to back up some old family videos and I went looking for "the cable" to do it.
I found this one in my local electronix store and it works a treat. The software package that came with it allows me too play tapes directly to the computer and then edit before saving them in a variety of formats.
www.magix.com
The cable was a bit pricey (€75) but the end result was over 40 hours of home video saved on a hard drive and made into DVD's for the family..
** A note of caution though, I found out a couple of weeks after buying it that this cable wouldn't work on MAC. Luckily we have a pc. Also, my laptop didn't have the power to process the streaming video so it was all done on my girlfriends... Again, I didn't read the small print on the specs requirements and the video is patchy and full of gaps when done on my laptop**
Hope this helps..
Oct 09, 2009 | Samsung VP-W70 Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Playing DV footage that was recorded on a different camera
Canon camcorders have a non-standard head position. Borrow a panasonic or samsung camcorder (those two are compatible) and backup your casettes on dvds. If you want them to be on minidv readable on canon camcorder, connect it afterwards and send video to minidv through your camcorder. It will then be alligned the way that suites your gear.
Either that or go to the professional service that does conversion from minidv tapes. That usually costs around 15$ per hour, so if you have 10 or more hours of video, the less expensive way is buying an entry model of panasonic camcorder.
Jan 03, 2008 | Video Cameras
Can u Create a movie(dvd) by mixing MiniDV format with JPEG?
Yes, this is frequently done. I think all video editors can do this. Windows Movie Maker or Roxio's Creative Suit are two that come to mind. Most of the lower cost products probably lack the ability to control the video and audio seperately. Someone else may be able to provide more options.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Cameras Logo
122 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
