Re Toshiba copy machine 4560
Machine powers on and asks for toner. We put in a brand new toner, but it still asks for toner.
Can you help
email jjh22@hotmail.com
  • 87 Answers
It needs a toner gear. There is a worm gear that drives a gear that drives the toner cartridge. An easy way to check, is to cheat the front door swith, and as it is running without the cartridge in, stick a pencil in where the gear is spinning. If it stops easily, the gear is probably worn out. Parts are getting hard to find for that model though.
Posted on Mar 19, 2008
Toshiba e 161 is running adding toner not ready
Power off the machine, remove the toner then power on the machine with no toner install let the machine run when it ask for toner install
Oct 29, 2015 | Toshiba Office Equipment & Supplies
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
Blank copies on brand new Toshiba e-Studio 120
Did you pull the plastic tape off of the toner cart?
Feb 18, 2010 | Toshiba e-Studio120 Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
How to change a toshiba bd-4560 toner cartridge
Look and see if part of the old toner cartridge is still in the machine.Compare the new and old cartridge and see if the shutter has come off the old cartridge.
Feb 28, 2009 | Toshiba 2060 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Feb 19, 2008 | Toshiba 2860 Copier
115 people viewed this question
jasbo
jasbo
