Question about Brother MFC-8840DN (Bundle) All-In-One Laser Printer
Brother Fax Machine MFC8840Dn broken hinge
The hinge on the lid of this copy/fax machine is broken? Can we get replacement parts or do we need a tech? The model is MFC8840DN.
  • 2 more comments
  • Anonymous May 03, 2008
    I took the broken hinge off but can't find a replacement. This is an easy fix since part is held only with 3 small screws.
  • Anonymous May 06, 2008
    BROKEN HINGES ON 3 DIFFERENT MACHINES ALL MODEL #MFC-8840DN
  • dhiggins Oct 26, 2008
    I have a broken hinge, left back side of copier lid. This is a plastic part.
  • MauiRay18 Nov 24, 2008
    Seem like a bad design in the hinge. Too much stress on a small plastic part. There should be a recall on this part.
    Ray - Hawaii
You can actually by the hinge itself for only 27$
the website is here: http://www.precisionroller.com/search.php?q=brother+mfc+8440+hinge&x=0&y=0
Posted on Jun 16, 2008
The part number is LP2422003. That is the entire lid with hinges that attach to the body. It costs $177. Hope this helps.
Posted on Jun 10, 2008
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper fan folds inside the fax machine.
THERE IS SOME THING BLOCKING THE PAPER PATH, MAY BE PAPER OR SOME THING FELL IN THE MACHINE GOOD LUCK BROTHER TECH
Jan 27, 2009 | Brother FAX-2920 Plain Paper Laser
Brothers fax machine can't send out faxes
try calling brother tech support  1-908-704-1700 good luck brother tech
Jan 05, 2009 | Brother MFC-8220 Fax
Fax machine is offline
what is a array sensor, i am a brother tech and never heard of an array sensor???????????????
Dec 30, 2008 | Brother IntelliFAX 5750e Laser Fax
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Copies with the Brother Fax-T104
I presume that it is possible to send a fax normally? To make a copy, the machine is basically sending a fax to itself. Therefore if it is possible to send a normal fax and setting the paper to make a copy in the same way as faxing doesn't allow the copy button to work, then the fault is in the machine. Believe me this machine isn't worth spending money on.
Dec 21, 2007 | Brother FAX T104 Plain Paper Thermal...
Brother MFC-8840DN (Bundle) All-In-One Laser Printer Logo
561 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
