Question about Compaq Presario 5000 PC Desktop
Compaq presario 5000 not booting up right.
When the comp is turned on it goes right to a screen that says to select 1 normal 2 logged 3 safe mode 4 step by step and says that windows has detected a registry/configuration error use SCANREG to correct this error but it won't allow you to do anything except select safe mode and then it gives a screen with the words safe mode in the 4 corners but nothing else. What do I do???? I have tried the F8, F1, and everything else I can think of including the restore disk, windows disk, and a repair disk all on start up but it doesn't seem to recognize the drives. What do I do???
    Novelist:
  • 139 Answers
Does the Compaq logo appear when you try to start the computer? Try pressing F10 several times after turning on the power. This should start the "recovery console", which will give you some options for restoring Windows. If the recovery console doesn't start up, there is a good possibility that your hard drive or power supply module may be defective. In that case, you will probably need professional assistance to diagnose the problem.
Posted on Mar 19, 2008
SOURCE:
Compaq presario cq on button keeps flashing and when I open laptop i get sign on screen but after I enter my password the scrren goes black and won't recognize control alt delete command to get to task...
before booting, try pressing F8 to get to safe mode, and there should be a safe mode option which will show you the flles as they are loading, while windows is booting.
Oct 28, 2010 | Compaq Presario 5000 PC Desktop
Compaq Presario-How to log on(XP) if don't know password?
Boot the computer into safe mode (tapping F8 while it is booting) and select the Administrator account. From there, go into control panel>user accounts.
Select the user account you need to access, modify password (you won't need to enter the current password in this mode).
Did this resolve your issue? If so, please rate it. ty.
Feb 28, 2010 | Compaq Presario 5000 PC Desktop
How do you unlock your computer if you forgot the password?
Do you have created the password reset disk ?
If you do, you can sign into safe mode and recover the password.
If you don’t have the windows password recovery disk. you have to take use of the third part utility, you can download it from http://www.windowsloginrecovery.com and the website will show how to recover windows password.
Feb 08, 2010 | Compaq Presario 5000 PC Desktop
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
STUCK ON LOG IN NOTHING MOVING LEFT OR RIGHT CLICK SCREEN SAYS ERROR IN APPLICATION FAILED TO INITIALIZE PROPERLY 0XC0000005 ISASS.EXE/APPLICATION ERROR
I'd try booting windows into safe mode and disabling windows firewall then trying to boot up normally. I've also heard this may be some kind of a virus.
Jan 23, 2010 | Compaq Presario 5000 PC Desktop
Safe mode
Get windows 7, or downgrade to xp. lol kidding. During the start up, i beleve its either f11 or f12 press them it should bring you to a boot screen. follow option. or you can use the compaqs built in recovery system. reinstall your system. vista has a option to save its old files for transfer.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
Start up problem!!
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Apr 26, 2009 | Acer Aspire 6920 Notebook PC
Compaq presario 5000 desk top
Try to load to safe mode ,do this after restarting the pc and before loading to windows hit F8, and chose safe mode, when u load to safe mode try to change the setting, hit apply and ok, then load to windows normally and let me know wat happen?
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 02, 2009 | Compaq Presario 5000 PC Desktop
Compaq
your comp was put on safe mode
Aug 11, 2008 | Compaq Presario 5000 PC Desktop
SAFE MODE
Provide more description regarding your issue. Is there any error message when you try to boot without safe mode? Does the computer just boot to safe mode without asking you anything? Andy
Aug 27, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
113 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
