Cannot get wireless connection to a laptop. Asking for wep code, but will only accept 10 digits. The wep code, according to my computer is much longer and is a mix of letters and numbers!!
    Novelist:
  • 139 Answers
What operating system are you using on the laptop?? Make sure you have selected 128-bit encryption rather than 64-bit encryption...if you have a choice.
Posted on Mar 19, 2008
SOURCE:
Can't connect to a wireless network
You didn't post the Make , Model of Wireless Device. Try a reset ot the Wireless device returning it to default settings and reconfigure the SSID and the Security Key. Setup the Wireless for WPA2-PSK security it's a bit more secure.
Apr 26, 2013 | Computers & Internet
I'm trying to connect wirelessly, but its asking for a sercurity key code! What is this and where do I find it? Help, pls!
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
Nov 22, 2012 | Computers & Internet
I need a wep key
A WEP key is a Wireless Network security key that allows your devices to connect to the Wireless network. It is usually a 10 digit code (alpha numeric) that is set on your Network DSL router. If you turn your router upside down, you can find it printed with a barcode on a sticker attached to the router.
See if this works before we get to a more complicated answer
Sep 11, 2012 | Video Game Consoles & Games
New laptop pc is asking for Security Key that relates to my Belkin. Don't know that #
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
Step 6 : IF the security mode is WEP then the key 1 will be your password
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Jan 06, 2011 | Belkin (F5D7230-4) Router (587009)
I just purchased a Netgear N300 wireless usb adapter. After installing the netgear software it ask for the WEP code off of the Centurylink provided Zyxel 660hw. The problem is the WEP code on the bottom of...
WEP code will be 10 digits only...you need to type all the 10 digits together (without any spaces)... Try disabling netgear utility and use your default windows utility...It is not the problem with netgear....
Aug 07, 2010 | Zyxel Prestige 600WH Wireless Router...
Linksys router, I do not know my own wep code to
1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 30, 2010 | Linksys Wireless-G WRT54G Router
Got a new laptop and can not connect, I put in the router pin # and it won't read, keeps asking for web security code and I don't know what it is? How can I connect, this is my old laptop and it works just...
When filling in the security code, it is usually asking for a WEP key. This is usually found on the back of the router itself. They usually have a 10 character alpha-numeric code. If your computer is asking for 12 digits, enter two zeros infront of the code listed on the back of the router and try it again.
Hope this helps
Jan 12, 2010 | Belkin F5D9231-4 Router
Hi I cant get my PSP to connect to my Belkin
The WEP CODE Is the Password for your wireless network
Dec 21, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
WEP key for 2wire 2700
The WEP number is in a wireless router near you, you must have a wireless router been setup in your home, then you have to program it. you choose your wep key code and only will have access to this wireless network.
contact your local IT or computer repair guy to help you with this process.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
How to connect my palm to my computer when I am using a reseault Linksys
hi. try this.
have the tx search for you network using the wifi button at the bottom of the screen.
select/highlight your network and click edit. note do not connect to it yet
click configure.
on the security, pull down the arrow and pick WEP (or WPA according to what your router has.) note that since you mentioned the 10 digit alphanumeric code i assume it is WEP
on the key type click on 40 bit hex
i usually leave the four keys unchecked. (unless you have 4 keys)
insert your alphanumeric key that you use to protect your network into the dotted line.
ok
ok
click yes to connect. enjoy.
if your pda has connected and you still cannot get your internet, please read below.
PS. some internet servers may require a new user to input a name and password as a safeguard. this is familiar when you try to log into a public wifi hotspot with your laptop and the web browser always redirects you to an agreement page.
if this is so, what i do is to run my internet browser. let it load the first page then i accept the agreement and i am in.
hope this works for you. please feel free to email me with any more questions.
enjoy
Sep 29, 2007 | Palm TX Handheld
Open Questions:
SBCglobal MAil NuMbE -+**/{1.855.536**5666}#[email protected] SERVICE This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 19, 2019 | Best Computers & Internet
SBCglobal MAil HeLpliNe *:{1-855*536*5666}#[email protected] PHoNe NuMbER PREMIUM This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
SBCglobal MAil HeLpliNe .:{1=855={536}{5666}#[email protected] NuMbER OREGON This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Computers & Internet Logo
59 people viewed this question
Ekse
Alun Cox
