Signal loss from GF9600GT to LCD 42PFL9632D
Hi Guys.
I have a signal problem from my pc - new GF9600GT to philps LCD 42pfl9632D.
It connects via DVI too HDMI.
I have tryed everything diff. cable/driver, resolution, settings, connections - nothing works.
I had the same problem, with a GF8600GT
The problem starts AFTER DRIVER INSTAL.
There are no problems on a GF6600GT
I suspect that some scaling or the new driver (174,53) is the problem.
Please help.
br
Paul
  • 149 Answers
The issue may be hdcp, if both the pc and tv arent enabled you wont get a picture.
try to connect dvi to dvi or if you havent got dvi try an adaptr
Posted on Mar 19, 2008
SOURCE:
Lcd philips 42pfl9632d 10
You may have to turn on HDMI on your laptop or load drivers?
Jan 28, 2014 | HP Computers & Internet
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
Hi, I get a No Signal message when I connect a DVI card. Does this monitor support this type of card? Regards, Pete
Hi Pete Not sure what you mean by connecting a DVI card.
This monitor is analogue only and must connect to the computer via a VGA connector. Are you using a DVI to VGA converter?
Feb 27, 2011 | Videoseven L19WA 19" LCD Monitor
I built my own computer a while ago. I had the Dell SE198WFP LCD monitor hooked up with DVI. My monitor was faulty and I took back to best buy and got a replacement. Ever since I got this new monitor, I...
some displays take a while to connect via dvi... not a problem, it just is... mine is the same way, it has to do with the vertical synchronization at signal detection... its common if the firmware in the display dosent get programmed to use dvi as primary signal..
it just happens
Feb 06, 2011 | Dell SE198WFP LCD Monitor
Can you fit a pc terminal to a shap aquos lcdtv??
sorry NO not just a connector would be nedded but serval are parts required
Nov 24, 2009 | Televison & Video
My monitor says there is no signal from my new Dell Studio
Try reseating the video card in your new computer. Sounds like it may not be seating in the slot properly. Take it out and put it back in with the power off and then hook everything back up and then see if you get video,.
Mar 14, 2009 | Dell Studio Slim-Tower Desktop Computer
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
May 16, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Ekse
