Question about AudioBahn A8002T Car Audio Amplifier
Amp making crazy noise
When i plug in my audio wires to my amp just starts throwing out crazy bass and when i tap my amp with my hand it makes the same noise and my power indicators are flashing red cant figure it out please help started happening out of nowhere
  • 24 Answers
What is your complete system set up?
Posted on Mar 19, 2008
I am adding a kicker 500 watt amp and a pair of 12" kicker subwoofers to my factory(non Boss - possibly Delco)audio system. I need to tap into the rear deck 6X9 bass speaker wires to make the kicker s
You will know if you have them O.O.S. ( out of synk ) they will simply not sound right. You want them hitting in the same polarity.
Make sure you check to see that you have disabled the on board amplifier(s) before just cutting the wires.
You didnt add any information about what type of automobile you have, other than saying "Delco" so I am assuming its a GM vehicle?
If so, you will want to Google " speaker wire color for (make/model/year)"
Jan 08, 2015 | Cars & Trucks
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
When i connect the bass boost remote controll on this amplifier, it seems to make the bass lag. Almost like the bass has a delay and not running synchone with the music. When i unplug the remote, all...
lets see so if u got the bass up with no swicth it hits like it should , try cuple things the swicth itself make shore there is nothing in where u plug it in on both ends , try ur acr wire unplug an plug them back in while the bass is off , try swicthing the controll wire around if able. i have had a amp that did something like that but i never had a controll hook up an it would hum when musice was off because the input for the acr wires was messed up . i hope this helps u out thank u
Jul 19, 2011 | Kenwood KAC-8152D Car Audio Amplifier
The amp turns on with a green light but the bass output is very low when i tap on the top of the amp it bumps for a split seconed and then stops usually when i tap on the side with the speaker outputs
Check the connections to the amplifier. Make sure that the insulation
for all wires has been stripped back far enough to allow a
good contact area inside the terminal block.
Check the input connectors to ensure that they all are making good
contact with the input jacks on the amplifier.
Sep 15, 2010 | Jl Audio e1800D Car Audio Amplifier
How do i check if my amp is still good?
first make sure that you have power check the red thick wire, and the remote wire with a voltmeter if its ok then disconect the rca plugs now get a pair of rca wires plug one end to the amp and touch the other end if it makes noise your amp is good ( please be very carefull as it will make a loud noise on the speakers when you touch the other end if the amp is good) good luck
Dec 16, 2009 | Car Audio & Video
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Noise in my car amp.
sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Apr 19, 2009 | Rockford Fosgate Power 1050S Car Audio...
Gain makes subs go crazy when turned up
HI DUDE UR AMP IS TO POWERFULL FOR THE SUB ... .... LOWER DOWN BASS IN UR PLAYER ... AND AMP .... TRY ADJUST BACK THE TUNE ... IT WILL B FINE ....
Apr 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Alpine MRD-M1005 Subwoofer Amp Problem
He may be right! You might try finding a new source of contact for your ground cause it may not be sufficent enough to ground to, also make sure that no wires from the back of your radio have any wires sticking out touching other interfering things that could possibly be causing the noise
Sep 14, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
AudioBahn A8002T Car Audio Amplifier Logo
73 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
