Roxio Creator LE Dell Edition - Purchased and installed on February 17, 2008
I started getting an error message when using the Roxio CD&DVD Burner. The message is as follows, "mediahub.exe application error" "instruction at 0x0036 add 3 referenced memory at 0x12963 a 4d". I have the Roxio Creator LE Dell Edition. The program was installed on February 17, 2008. Less than one month after installation. I have continually written thecompany for help and can not get a response Surmeek @sbcglobal.net
  • 655 Answers
Your program is making conflict to operating system, its trying to read some thing with invalid memory address. This may be due to curreption of your application.
If thats the case with you, reinstallation of the application will fix the problem.
Uninstall the Roxio from your system, then reboot to clear completely the components of the application. Then install.
Thanks
Iqbal
Posted on Mar 19, 2008
Pc installed burner is not recognized by roxio easy cd & dvd creator 6
Hi there
Try to go to Roxio Support here :
https://selfserve.roxio.com/%28S%28heybe055ok2x3k45vykq4045%29%29/Login.aspx
I am sure they can help
IF NOT then return here
Hope that helps
Have a nice day
Please rate my anwer
Sep 29, 2009 | Roxio Easy CD & DVD Creator 6...
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
Roxio creator 2009 burning issues
Here's a few things you can try:
1.) Download Service Pack 3 for Creator 2009. This updates the software and is recommended.
http://www.roxio.com/enu/support/c2009/software_updates.html
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
http://kb.roxio.com/search.aspx?URL=/content/000070GN&PARAMS=set-locale=en
4.) If all else fails, try visiting this KB article:
http://kb.roxio.com/search.aspx?URL=/content/000008GN&PARAMS=set-locale=en
Apr 04, 2009 | Roxio Creator 2009 for PC
Error when attempting to write disk
Sometimes the driver that is used to burn CD's gets corrupted, you should try removing and re-installing roxio. The only other possibility is a bad CD burner drive, but these are dirt cheap to replace these days, you should easily be able to find one under 40$.
Jan 20, 2009 | Roxio Easy CD & DVD Creator 6...
ROXIO CREATOR LE DELL EDITION CAME WITH MY COMPUTER AND WORKED PERFECTLY UNTIL SEVERAL MONTHS AGO. I CAN BURN DVD'S, AND I CAN ADD PICTURES TO A DISC WITH PICTURES IF IT SAYS APPENDABLE. WHEN I PUT IN A...
Ok - the link I found for a fix for the error messages also seems to have fixed the problem with disks not being recognized! Apparently it is all linked to WMP 11. So....here's the link to the fix:
http://kb.roxio.com/content/kb/Creator/000058MD
Jun 25, 2008 | Computers & Internet
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Drive E No Burnability
CD\DVD BURNING Downlaod a Free CD\DVD Burner Software here >> http://infrarecorder.sourceforge.net/?page_id=5 First Check the Data cables starting from the Motherboard then on the Drive Note on PIN1. It is suggested that a CD Drive should be slave to a Master HDD so set the Jumpers properly. Hope this helps =============================================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 18, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Roxio
do you have a CD\DVD burner installed hardware?
Sep 15, 2007 | Roxio Easy CD & DVD Creator 6...
Computers & Internet Logo
233 people viewed this question
Alun Cox
David Payne
David Payne
