I bought my sister a laptop about a year ago and when she went to bed the other night she put it on sleep mode. Now when she tries to turn it back on the screen will not come on and it makes this beeping noise when she tries to turn the laptop on? Can anyone help?
I also have the same problem. I own a HP dv6000 laptop. when I turn it on, the screen remains black and there are 3 beeps, and then it remains like that. I brought it to be check but they told me probably it would be a motherboard issue. However, sometimes it just turns on normally, but when I reboot or turn it off and on again I have the same problem. It's new and the battery and power supply are OK. Who can help?
My computer has the same problem.It is hp pavilion dv6000 model. The computer is on but no signal.It beeps.Initially,it use to work after removing the battery but now it does work.I need a solution
Solution #1
posted on Jun 10, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
none of the above answers are close to the problem... the number of beeps and length of each beep can tell you what the problem is related to this may help: http://www.pcstats.com/articleview.cfm?articleID=1223
Was this solution helpful? Show your Appreciation by rating it:
The battery may be too low. Try leaving it connected to the charger for awhile. If it doesn't recover, remove the battery and try to turn on the computer with the power cord connected. If it works, the battery is probably defective. If it doesn't work, the power adapter could be bad...or the computer has another problem such as a failing display or hard drive.
