Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Refrigerator i have to tap the refrigerator control part to get it to run. it runs for about 1 hour then i have to do it again because it stops running. i replaced the cold control and the defrost thermostat. the model number is 106.9555711
    Master:
  • 788 Answers
There is probably a cracked solder joint or broken component. Go over the board with a fine toothed comb and resolder any components that are loose.
Posted on Mar 19, 2008
    Guru:
  • 1,894 Answers
Then i think the gas flow is getitng obstructed
  • dewan nafees ahmed Mar 19, 2008
    else there must be some problem in the input power.
    this will also make the unit to stop due to over heating.
    also please have a check with the power getting in
Ed25e refrigerator running inconsistently
the knob you're turning is the cold control,it's a thermostat and it's sticking,when you turn it or tap on it you're freeing it up,you need to change it out .go here and see the part and part number 819470 it's around 55 dollars
http://www.repairclinic.com/PartDetail/Temperature-Control-Thermostat/819470/2361
when you remove the old control install the new one the same way,you might have to bend it a little and you have to cover the metal rod with the plastic cover that comes with it.not hard to do.
Sep 01, 2012 | Refrigerators
It does not cool up and does not run but if i tab the light inside it runs for a while and stops again without cooling.
It sound like you have a bad temperature control.If you can tap it to make it run it must be bad or maybe a loose wire. Hope this helped and thank for using Fix ya
Jun 19, 2011 | Refrigerators
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
Refrig and freezer wont stay running shuts off when it feels like it tap on temp control starts to run again
if tapping on control start's it up then i would replace cold control / as is see it . this is the problem . / **** hope this helped . ****
Jan 02, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Whirlpool Refrigerator Stops Running
I can help with this issue , Take the cover off with the controls to see inside , make sure all wires are connected to t-stat it will have a slim tube coming out of it , if there all intact it is a bad connection in the bi-metal inside the tstat which can not be repaired. you must replace your thermostat. sears parts topically has the best price. hope that helps you out , let me know if you have any prob. or questions. Phil
Dec 31, 2008 | Refrigerators
Refrigerator not colling properly
Let it run until you have a problem again then look at the back wall of the inside of the freezer, if there is frost then it's not defrosting and that would be your problem (usually the defrost heater). If you don't see frost then you need to determine if the compressor is running or not. It's possible to hear the two fans run, but not the compressor. If the compressor is running, along with the 2 fans, then it is a sealed system problem and usually not worth fixing. If it's not running you'll need to check the compressor start relay on the side of the compressor. It is possible for a bad compressor to cause the relay to fail, so replacing it may or may not get you going again.
Jul 21, 2008 | Kenmore 53642 / 53644 Side by Side...
Runs, but not automatically.
replace the thermastat or also called the cold control
May 14, 2008 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
