Question about Mitsubishi VS-55705 55" Rear Projection Television
Color alignment can I adjust the lenses manually? blue is slightly twisted and red is shifted so it won't line up.
    Guru:
  • 1,894 Answers
Which lens are you talking about?
there is no such one i think
Posted on Mar 19, 2008
  • dewan nafees ahmed Mar 19, 2008
    To perform a proper alignment, you always have to take the green line
    as reference.Then it will not have any problem.Bring the others that is
    blue or red to this green and make sure that green is at the center of
    your TV.
    If they don't move, replace the conv ICs.
SOURCE:
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
When tring to use the red convergence it seems to be twisting.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Mar 07, 2009 | Sony KP-61XBR48 61" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
I have a hitachi 50FX18B and the convergence lines are not aligne
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 24, 2009 | Hitachi 50FX18B/19K 50" Rear Projection...
Green tint on Samsung Television
Hi sbatsch,
Not to worry - this problem is very common with projection TVs and is easily fixed:
The reason for the green shadows (and the resulting wrong colors) is that the three color tubes (red, green, and blue - the three colors of light that combine to form all the other colors) are not lined up exactly - this lining up is known as "convergence." You can fix convergence automatically or, if it doesn't work to your satisfaction, manually. Here's how:
Automatically:
1) Press MENU.
2) Go down to CONVERGENCE (using the up and down arrows)
3) Select it (usually with the left or right arrow)
4) Go down to AUTO and select it - the process should take about a minute.
If this doesn't work, then try manually:
1) MENU
2) CONVERGENCE (as above)
3) Select MANUAL
4) Using the number keys, SELECT, and the arrow keys, adjust the alignment of the different color crosses - the goal is to make them appear white (meaning that the red, blue, and green are exactly aligned on top of one another).
Here's a link to the JVC user manual that will explain the manual convergence adjustment in more detail.
http://resources.jvc.com/Resources/00/00/96/52105ien.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
