Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 Printer
Every time that I try to print it prints up to 99% then stops and stoarts to delete the print job. I have reloaded the start up disk that came with the printer but it keeps doing it. HELP!
~Lee
www.pastorleejones@hotmail.com
  • Anonymous Mar 23, 2009
    Stops printing at 99%
I can receive fax but cant send fax
Posted on Mar 25, 2008
Printer shows job in progress so cannot uninstall
Make sure there are no print jobs stuck in the print queue so you can successfully uninstall the printer from your computer. You can try this approach:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
When the print queue is cleared, try to uninstall again.
I hope this helps. Thanks.
Oct 20, 2011 | Lexmark X4270 All-In-One InkJet Printer
PRINTER WILL NOT PRINT THERE IS A JOB THAT WON'T CLEAR. I TRIED DELETING THE JOB AND ALL IT SHOWS IS THE JOB DELETING AND THATS WHERE IT'S STUCK
To clear the print queue from stuck print jobs, try this approach instead:
Oct 02, 2011 | Lexmark X2500 All-In-One Printer
I have a printing job stuck in the printer que and my printer will not print now. What do I do? I've unplugged the printer from the wall for a minute and even held down the power button and it's...
Try to follow the steps below to fix the problem:
Try to print a document again to verify that the problem is fixed.
Sep 03, 2011 | Lexmark X4270 All-In-One InkJet Printer
My lexmark x2500 printer keep print the same thing over and over. how do t fix the problem? speciallady1946@yahoo.com
It could be that the same print job is on queue to the printer. Try to delete all print jobs in the queue before sending out a new one. Follow the steps below:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service) 2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. 3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service) Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh. Try to print again.
Jun 20, 2011 | Lexmark X2500 All-In-One Printer
Hi. My lexmark z640 printer has stopped working. When i double click the z640 icon on the desktop the window opens and says that the current job is deleting, this has been like this for hours. tried to...
Try to clear the print queue first before sending a new print job. Follow these steps to clear print jobs stuck in the print queue(for Windows):
3. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
4. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
5. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 27, 2011 | Lexmark Z640 InkJet Printer
Says it cant use printer due to error with printer. It says officially "windows cannot print due to a problem with the current printer setup" it is a lexmark x2350
Make sure you delete all print jobs. if you have tried that I suggest your next step is to reload your driver.try deleting and reloading your driver.
Oct 10, 2009 | Lexmark X2350 All-In-One InkJet Printer
Printer will not print page 2 of a cancelled document, nor anything else since
you need to stop and restart your print spooler service. From the control panel, select administrative tools, then services. find the print spooler, right click and stop. then right click and start.
This should clear out the stuck print job. and free up the printer.
Sep 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Stops at 99% and trys to delete file - no other jobs will print
This is based on your operating system and should work for all versions of XP, I have not tested it on Vista.
Start, Run, type "services.msc"
Find "print spooler"
Click the stop/start icon (square with triangle at the top of the screen shot below)
Try to highlight your print job and clear it.
If it will not, power down your printer, power it back on (physical power) and try again.
Feb 03, 2008 | Lexmark X6170 All-In-One InkJet Printer
Caught in spool, can not cancel or print
Been working on my computer for two hours on this problem!
i could not cancel what was in the spool
do this
If you are on Vista Home Premium, go through the following steps to clear "deleted" print jobs from the print queue.
1) Go to Control Panel
2) Select System and Maintenance
3) Select Administrative Tools
4) Double-click on Services
5) In the list of services, scroll down until you find one called "Print Spooler"
6) Right-click on "Print Spooler" and select "Restart"
7) The "deleted" jobs will disappear and any queued jobs in your print queue will print
Hope this helps. I figured it out on my own without any assistance from the paid professionals
Sep 09, 2007 | Lexmark X4270 All-in-One Multifunction...
Lexmark X4270 All-In-One InkJet Printer Logo
117 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
