WATER LEAKING UNDER THE INDESIT WASHING MACHINE. MAKES TOO MUCH NOISE. WALKS AWAY SOMETIMES!
  • 552 Answers
Check by taking off the top of the machine.
There may be screws behind it at the top that fasten the top.
Take them out and push back hard and lift the top.
Otherwise if yours has spring clips under the top at the front, then get a screw driver and push in at the clips which should be visible under the front edge of the top to release the two clips.
Then examine what seems to be leaking by looking down inside.
if not visible that way, you can tip it on it's front and look at the bottom of the machine.
Then tell mne what you see leaking.
Posted on Mar 19, 2008
Washing machine makes clicking noise after filling up and wont spin. Kepps on clicking until i force shutdown, which then drains the water away.
hi, the problem you have is the motor carbons (brushes) have worn down ( which is natural if machine is used every day ). the machine fills up with water but there is no motor action. the clicking noise you are hearing is the relay on the pcb sending a signal to the motor to turn, but with the carbons worn, there is no motor action. Easy enough to replace them. UNPLUG machine before any repairs are carried out.
Dec 19, 2013 | Indesit Washing Machines
Indesit wil103 guides
Reset the machine by unplugging and see if that will help.
Oct 15, 2013 | Indesit W 123 Front Load Washer
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
Dec 29, 2007 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
