Question about Vivitar 285HV Flash
Vivitar 285 How do I set a Vivitar 285 Flash unit to expose ISO 400 film automatically at F/8 and at full power?
YOU ALTER YOUR SHUTTER SPEED TO THAT WHICH IS INDICATED ON THE DIAL ON THE SIDE OF THE FLASH. AS THE FLASH WILL FIRE FULLY ON "FULL FLASH", YOU HAVE TO ALTER THE SHUTTER SPEED TO ATTAIN THE CORRECT EXPOSURE, OR "BURN" ON YOUR ISO 400 FILM.
Posted on Sep 25, 2008
    Champion:
    Scholar:
  • 216 Answers
By looking at the scale on the right side of the flash.
atdlee@netzero.com
Posted on May 19, 2008
I bought this canon rebel t2 film camera recently and used film with ASO 400. Portraits look ok. but the landscapes, especially the sky area look dark and grainy. I used ef 28-135mm usm lens. Any solutions...
That's odd that the pictures would be coming out under exposed unless the previous owner has gone into the camera functions and switched the ISO from auto to manual. Another reason is that the exposure compensation has been activated and set for - exposure
Under "normal" use the camera will read the DX code on the film canisters and adjust the ISO automatically. However the previous owner may have shut this off in preference to setting the ISO manually. Even though you have ISO 400 in the camera the ISO on in the camera setting may be ISO 1600.
Checking for the Auto ISO and exposure compensation is fairly easy as you can see the film canister through the film window or you know you have loaded 400 speed film. on the LCD panel at the back of the camera is an ISO icon and exposure compensation.
Make sure the ISO for the camera is the same as what you have loaded and if the exposure compensation is to the right of 0 then the resulting picture will be dark. Move this back to the Zero.
I wasn't able to find an exact manual (if you don't have one) for your camera but have found a camera with similar. Here is a ling for that manual.
http://www.butkus.org/chinon/canon/canon_eos_rebel_ti/canon_eos_rebel_ti.htm
Hope this was a help
Dec 18, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Is there a way to turn off the flash?
The flash is automatic, you cannot control the flash. But you can put some black tape over the flash if you really don't want flash. Remember though, if the camera meter decides flash is needed, then your pictures could turn out dark/underexposed by covering the flash.
The manual can be found here: http://www.olympus-europa.com/consumer/208_manuals.cfm?prodID=P_N1246352
The manual says use 100, 200 or 400 iso films.
Maybe try high iso film like 800 iso or 1600 iso, best to try this out ahead of time to make sure you are satisfied with the results. The high iso films need less light so should perform better without flash, but the camera may not be able to rate these films correctly, trial and error is definitely required.
Oct 22, 2010 | Olympus TRIP AF 60 35mm Film Camera
Vivitar 285 not working
You don't need a Manual.
In 285 HV there is only one Power on/off switch.
If that switch is on and batteries are new Alkaline (like duracell-no chepo )or fully charged and working rechargebles,and yet the ready light do not come the flash has defect inside.For sure.
Jul 27, 2009 | Vivitar 285HV Flash
What Film Should I use for Vivitar V4000?
try Kodak ISO, ( ASA), 400 ( DIN 27 Degree ) 35 mm film to start. if you like the results, stick with it. remember the faster the film the higher the grain. the slower the film the finer the grain, sharper enlargments with finer grain.
Jun 07, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Vivatar 285 HV flash problems
Are you still having problems? a.l9609@gmail.com
Mar 09, 2009 | Vivitar 285HV Flash
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
Canon 430 EX flash problem
Were you indoors? if so, take the ISO of AUTO and out it on 400. Leave the camera set like you had it, Manual 1/60 @ 5.6. Do notuse evaluative metering. Use single spot metering or the smallest center weight setting.
Jun 28, 2008 | Cameras
Shutter speed
Did You ever use a SLR back in the stone age when all we had was film?
Film was/is rated with a ISO number, the higher the number the faster the film.
Fast film had fewer and larger grains of silver iodide, (the particles that changed tone, color etc.when exposed to light), therefore it took less light to take a picture.
The down side was a increase in grain. Large grains meant that blow ups, 8x10, 11x14, posters, etc were not as sharp,
as with slow ( low ISO film)
Most outdoor photos had plenty of light so the film had more grains ( high ISO) to capture the available light, and the result was a much sharper image.
Portrait photography used very very slow film ( your 50 ISO setting) but in a studio you had all the artificial lighting you needed, so your portrait came out with very fine detail.
Now the FE-280 does not have a shutter setting, but we can compensate by changing the ISO setting, and the overall effect will be.
Fastest= 1600 ISO for very little light and poorest picture quality.
Slowest=50 ISO for plenty of light and the highest picture quality
200 ISO was the most popular because it worked well outdoors and indoors with a flash, with very good overall picture quality.
400 ISO was a good choice for gloomy days and medium lighting conditions.
Your ISO settings on the FE-280 will have a similar effect.
My best advice is to play around with the different settings until you develop a knack for it, we used to use light meters and a lot of guesswork, quite expensive when you had to buy film and pay for processing.
OK enough history. heres how....
Turn dial to (P) PROGRAMAUTO
Press (MENU)
The camera menu in center is bracketed, Press (OK)
Scroll down one bar on the on screen menu to (ISO)
Press (OK)
Scroll up or down to desired ISO
Press (OK)
TAH DA !
All other functions will be automatic or any other setting that you might choose..
If you change the dial and later go back again to (P) it will retain your selected ISO setting, which is displayed, on screen.
I hope I was help full, and you enjoy some of the special effects that you will now be able try.
By the way... good taste in cameras.
Best regards, Paul
May 18, 2008 | Olympus FE-280 Digital Camera
External flash for the 3000Z
bought the Metz 32 Z-2 that was recommended by Epson. I did a great deal of searching/researching on the web, and eventually came to the conclusion (my personal conclusion...YMMV..as well as others) that it was worth the price. I've also had two (non-digitial) pros hold the metz name in very high regard. I like it so far although I haven't used it much for nice portraiture. I did use it at the beach one night in the *dark* from 10 meters (couldn't see *anything* on the LCD when snapping the picture) and a few turned out really nice. Some were not in complete focus, but hey, it was dark. I will say it is much larger than I expected. When mounted on the 850 it felt nice. But with the 3000 being a little smaller, it is rather large. With a teleconverter lens and the flash mounted together, the whole ensemble feels rather nice. I'd recommend finding one in person first. It does have about all the features one could want tho...
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Vivitar 285HV Flash Logo
162 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
