Question about Mitsubishi WD-52628 52" Projection HDTV
Flashing green timer light, no image on TV
Green light for timer continues to flash without image on screen. Stops flashing and then cycle repeats itself. TV will not respond to remote while this is happening.
  • 4 more comments
  • Anonymous Mar 20, 2008
    ongoing flashing timer light, no video image, no response to remote. Becomes repetitive cycle
  • Anonymous May 15, 2008
    flashing green timer light, no image on TV problem
  • Anonymous Aug 14, 2008
    Same problem listed above
  • mccauleybjse Sep 07, 2008
    Mitsu WD-52628. Purchased 01/14/2006. We had a 2.5 hour power outage yesterday (TS Hanna). Power returned. HD-DTV reacquired signal and TV performed fine. No action needed. Today: Turned on TV. NetCommand prompt to re-program settings on screen. Did so. No issues. Turned off TV. Turned TV back on 2 hours later. No picture on TV. Nothing. Intermittent flasing timer light (green). Reviewed very non-intuitive Owner's Guide for the umpteenth time. Tested all connections and power sources. Nothing in the troubleshooting section of Owner's Guide suggests a solution. Contacted Mitsu Tech support. No substantive remedies suggested except to conatct authorized Mitsu tech support. Sugggested solution on this site to replace four internal capacitors sounds hopeful (and not to be a doubting cynic), but is this a proven solution? Thanks.
  • Anonymous Oct 24, 2008
    exact same problem! will NEVER buy a MITS again.
  • Anonymous Dec 06, 2008
    I have the same problem. The entire DM Board needs replaced in addition to another part. Looking at almost $500 in parts to repair. I will NEVER purchase anything associated with Mitsubishi EVER again. I purchased my TV in 3/2006, the 52628, and not it it is a pile of junk! Totally disgusted.
  • Mitsubishi Master
  • 8,617 Answers
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Posted on Mar 19, 2008
  • charlie Brooks
    charlie Brooks Nov 26, 2013
    Any idea of where to get them and cost? And what a TV reparman would charge?
SOURCE:
Sony Bravia KDS-55A3000 while watching last night screen went black as if someone turned the TV off when attempting to turn it back on the the power indicator light flashes green repeatedly stops then a...
It sounds like the lamp has failed. It is advisable to use a genuine Sony lamp. The part number for is XL-5200. It will cost around 180.00. That should fix you problem. If you cannot find the lamp local to you can order it form Sony at.
1800-222-SONY
I hope this help,
Skyassoc
Dec 15, 2010 | Sony KDS-55A3000 55" HDTV
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Flashing green timer light on TV
change the 4 100uf capacitors on the DM board. You will need the service manual to get the set apart as its technical. But with the service manual and take notes you should be able to repair it. But the service manual for that chassis is mandatory or you will never get the chassis out without alot of trouble. Heres a link where you can get the manual emailed to you.
http://servicemanuals.vstore.ca/
Mar 20, 2008 | Mitsubishi WD-52628 52" Projection HDTV
My tv video is turn off but sounds perfect
donot quickly replaced the tube! try this first get 2 megohms 1/2w resistor solder it between blue gun and green gun.if this make the picture still, bad tube.u can still rejuvinate it.if not,bad capacitor in vertical or bad g2(screen) adjuster.
Mar 24, 2007 | Sony KV-27V10 27" TV
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Mitsubishi WD-52628 52" Projection HDTV Logo
872 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
