Question about Philips SA5125/37 MP3 Player
DAVID IN THE SCREEN APPEARS THE MESSAGE "MEMORY CORUPTION, REPAIR NOW"
  • 8,596 Answers
You must do a firmware upgrade to resolve this issue.
Open Philips Device Manager (Go to Start--> all Programs--> Philips...), and click on Update tab
OR
You can get it from www.usasupport.philips.com
It will delete all songs off your player, so be forewarned
Enter your model number on the website, click the link on next page that says SA 5125/37 w/o a "b" on the end
Click on Software and drivers tab
Click on firmware upgrade software - instructions enclosed
Posted on Mar 20, 2008
SOURCE:
I have the below mentioned printer a
Hi Peter.
  1. Turn off the machine and unplug the power cord from power supply
  2. Plug the machine back in and turn the power on
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory will be deleted
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre. I am assuming it has run out of warranty, so any repairs will cost you.
You can find the details of your nearest repair centre using this link interactive repair centre locator.
Also It may be worth checking the roller bar and rollers to ensure they are running at the same speed when flipping the paper over.
Regards
David
Dec 03, 2017 | Canon PIXMA MP600 all-In-One InkJet...
How can i repair corrupted memory card?
Test yuor memory card in other cellphone,,
or plug it in on computer to see if the memory card is
still good or it was totaly corrupted.
if you mmc is real corupted,,you can use this to recover your files
download this and install it on your computer
memory card recovery tool
Nov 03, 2012 | Cell Phones
Last 3 days Msg appeared : some data corupt. Now the phone automatically shuts, changes its profile & restarts
remove your memory card and switch on. if there is no problem then memory card will be corrupted. just format it. then also problem means u should format your phone memory. just reach your nearest nokia service stations.
Aug 09, 2011 | Nokia N72 Cellular Phone
My nokia n900 device memory is corupted
Whenever you receive a message saying the memory card is corrupted, this means that there is a virus or some sort of dangerous file which is trying to or disfigure your phone system.
Normally there are two ways to go about this problem, one of which is to make a complete back-up of all your files and then do a format of the memory stick or of the phone memory depending on which memory is corrupted.
Also, you can connect it to your computer if it is the memory card and then use a good anti-virus to scan your memory card, normally if it is a virus it should eliminate the virus while scanning.
Lastly, if the message is from your phone memory, then the only available option is to flash the phone memory and this requires expertise and should be sent to a repairer.
hope this solved your problem?
Jan 01, 2011 | Nokia N900 Smartphone
PLEASE, I HAVE A DELL D610 LATITUTUDE LAPTOP AND I WAS WORKING WITH BEFORE A BLUE SCREEN APPEARED WITH SOME ERROR MESSAGE, AND NOW THE HARD DISK IS NO LONGER RECOGNIZING, WHEN IT DOES IT ODSN'T ALLOW ME TO...
Blue screen error may generally appear for three important reasons : 1.If you system is infected with some viruses and your hard drive has bad sectors in it.
2. If your memory card has gone bad or not properly pluged.
3. The OS has gone corupt due to virus attack.....
Resolution: 1. Go ahead and do a complete format on your hard drive and then install the OS, i.e., Win XP.
2.Try replacing your Memory Card in your system.
3. Change your hard drive or conatct Geek Squad @ 1-800-433-5778 for data recovery.
Jul 29, 2010 | Dell Latitude D610 Notebook
Memory Card corrupted
test yuor memory card in other cellphone,,
Jun 04, 2010 | Nokia N70 Cellular Phone
A move corupted
this occasionally happens when the memory card writes the file with an error. A picture would be corrupted, this is appearently what happened to your movie. I not know of a way to save your movie. It is very likely lost.
Oct 24, 2009 | Panasonic Lumix DMC-LX2 Digital Camera
Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Jul 17, 2009 | Dell Inspiron 1525 Notebook
"out of memory" message then printing to screen and printer
You would need to increase your virtual memory and restart your computer. Windows XP:
Right click my computer, go to properties
Select the advanced tab
Click advanced tab
Click change under virtual memory.
Set virtual memory 1500 to 4000
click set and apply, ok
If the memory is set higher, select a higher number.
This should resolve your issue.
Feb 06, 2009 | Microsoft Works 8.0 for PC
Need help
Error messages seen at power-on if not caused by the memory card are generally related to the lens assembly either being jammed or malfunctioning. We do not see many Casio cameras here in my shop but I can say that statement applies to these kind of cameras in general. Hold the camera close to your ear when you power it on. Do you hear a series of different sounds, or do you hear chattering or repeating sounds? Perhaps no sounds at all? David Millier Advance Camera Repair
Feb 20, 2007 | Casio Exilim EX-S3 Digital Camera
Philips SA5125/37 MP3 Player Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
