Question about Apple iPod nano 3rd Generation
Ipod nano won't connect to iTrip car system
Ipod nano won't play on iTrip car system. Returned accessory thinking it was defunct but new one does the same thing. All our other ipods of the same model work fine with car system. When I try to connect this particular ipod it won't play and freezes up. It will allow me to reset manually once I disconnect from car accessory. Ipod does, however, connect with no problems to my computer for syncing and charging. Thanks in advance.
  • 2 more comments
  • Anonymous Apr 15, 2008
    yea i got the itrip auto and iv tried all the little things they tell you to do to get the itrip and the ipod nano to communicate or wat ever but it just freezes up i can even play a song and then plug the itrip into it and it will play for about 3 seconds and then the ipod freezes up again but when ever i disconnect it it works fine so i have no idea wat the problem is
  • Anonymous Apr 20, 2008
    My Ipod nano 3rgG won't play on iTrip car system. All our other ipods of the same model work fine with car system. When I try to connect this particular ipod it won't play and freezes up. It will allow me to reset manually once I disconnect from car accessory. Ipod does, however, connect with no problems to my computer for syncing and charging.
  • tommyboy160 Jul 25, 2008
    Ipod nano won't play on iTrip car system. Returned accessory thinking it was defunct but new one does the same thing. When I try to connect the ipod it won't play and freezes up. It will allow me to reset manually once I disconnect from car accessory. Ipod does, however, connect with no problems to my computer for syncing and charging.
  • Anonymous May 06, 2009
    I have the same problem.. What is the solution??
    New Friend:
  • 3 Answers
You might need to check which version or generation your iPod Nano is because older versions use a different voltage in power then the newer generations. Older generations will blow the iTrips fuse or may defunct the nano.
Posted on Dec 21, 2012
Yea i got the itrip auto and iv tried all the little things they tell you to do to get the itrip and the ipod nano to communicate or wat ever but it just freezes up i can even play a song and then plug the itrip into it and it will play for about 3 seconds and then the ipod freezes up again but when ever i disconnect it it works fine so i have no idea wat the problem is
Posted on Apr 15, 2008
  • Apple Master
  • 13,433 Answers
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
Posted on Mar 23, 2008
Updated my ipod software and now it wont play on my home theatre system
This is always tricky with 1st generation iPod touches. After a while they can't handle the new software anymore and some functions won't work anymore. Maybe try to downgrade the software. Otherwise you should probably get a new iPod.
Aug 21, 2012 | Samsung Home Theater: HT-C5500 MULTI...
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
I have an itrip (2009) for my iphone, but as soon as I plug the dock connector, I got a message that says that such app is not recognized for my iphone
Hello Hinost,
The Griffin iTrip is a device that is compatible with Apple's iPod and its main function is to allow a user to listen to their iPod in their car. The device sends data through radio signals and it assigns a radio station you want to tune.
Update your iPhone if your Griffin iTrip is not working. This has been known to fix fourth generation iPhones. Plug your iPhone into your computer and launch iTunes. Under the "Devices" tab, click the "Update" button to update your iPhone firmware. Try using the Griffin iTrip again.Perform a soft reset on your Griffin iTrip if it is not powering on. Sometimes the iPhone has problems communicating with third-party devices and can lock up or freeze the third-party device. To perform a soft reset, plug the iTrip into your iPhone and make sure the iPhone is powered on. Hold down the "Menu" and "Select" buttons on your iPhone until the Apple logo appears. Try using your iTrip again after this reset.Make sure that the iTrip is completely flush with your iPhone when it is connected to the iPhone.If your iTrip is set to a station that is close to a major broadcasting station, you may be getting interference. To change the station frequency, navigate to the iTrip playlist on your iPhone.
Jun 06, 2011 | Griffin Technology iTrip Controller
What itrip griffin that fit in ipod a1285
A1285 is a 4th generation ipod and most itriffin is compatible in most ipod.
itrip griffin compatible on your device is:
itrip_4060.jpg?1253638087 iTrip $49.99 FM Transmitter with App Support
NA22045
Please click the link for all accessories compatible to your device: http://www.griffintechnology.com/device_types/ipod/devices/nano4g
Feb 18, 2011 | Apple iPod nano
Why is my itrip screen blank?
The battery is probably too flat to be recharged via normal methods, you need to get a new battery, or take the old one out and charge it with a higher power charger.
May 11, 2010 | Griffin Technology iTrip FM Transmitter...
Itrip screen flashes and wont start
From the Griffin website: "This means that the iPod you're using isn't compatible with the new iTrip. The new iTrip with App Support requires data connections that aren't available in iPod models made before September of 2007. The good news is, there are plenty of iTrip models that are compatible with your iPod. For a complete list of Griffin products that are compatible with your iPod, go to our Products page and click on the picture of your iPod"
Dec 17, 2009 | Apple iPod MA446LL/A MP3 Player
How do i use a griffin itrip?
you'll have to tune your radio to a certain station. 89.5 might be it. do a seek on your car radio while your iPod is playing to verify the correct frequency.
Sep 19, 2009 | Griffin Technology iTrip FM Transmitter...
Does this play the new 4th Gen Nano?
Try MSCONFIG and always run the computer in selective startup
Feb 14, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
My Jamo i300 will not charge my new ipod nano (4th Gen).
not likely the new 4 gen Ipod has different pin set within its dock connector system for the video output which has made many 3rd party accessories no longer able to charge the ipod but it will still play music
Jan 15, 2009 | Audio Players & Recorders
Apple iPod nano 3rd Generation Logo
220 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
