Question about Brother HL-2040 Laser Printer
Toner light won't go away.
Describe your problemMy printer is showing the toner is out. I replaced the toner and held down the go button and its still showing the toner light on. I tried printing and it doesn't print. What can I do?
  • 15 more comments
  • Anonymous Mar 21, 2008
    same problem here. I tried the procedure below and I did not work -- toner light is still on
  • FORK6996 Mar 26, 2008
    TONER LIGHT WON'T GO OUT. REPLACED TONER, DRUM, TRIED RESETING. NOTHING WORKED
  • Anonymous Apr 03, 2008
    same problem - no further comment
  • Anonymous Apr 18, 2008
    same problem
  • gracie66f Apr 25, 2008
    Toner light keeps reappearing even after shaking and changing Toner Catridge. Driving me crazy -- esp. when doing taxes!!!
  • Jay425 Apr 27, 2008
    The toner ran out. I installed a new toner cartridge, but the toner light didn't go out, and it won't print. I installed a new drum/toner assembly and it still wouldn't work. I tried re-installing and that didn't work either. Help!
  • Anonymous May 01, 2008
    changed toner tonerlight won't go out won't print
    changed toner toner light stays on won't print
  • Air Chek May 06, 2008
    I have the same problem with my HL-2040 and tried the fix. According to the instructions, after step 6 the ready light should turn red. This does not happen and when I close the door the toner light comes back on.
    Any other suggestions?
  • Anonymous May 13, 2008
    MY tonor light is on. The HL-2040 will not print.
  • Anonymous May 25, 2008
    solo esta prendida la lus de toner y no copea
  • monster rain Dec 10, 2008
    only prints one page ,then toner light comes on.
    I then take out the drum,remove toner cartridge and manually turn the gear until the little white lever starts to raise.If I then reinsert the drum and toner I can get it to print ONE page then the toner light comes back on and I must repeat the process for each page.The print quality is fine by the way.
  • sevensamuri Jan 02, 2009
    toner light stays on and won't print
  • sewabaraha Apr 06, 2009
    i have the same problem like my toner was finished and changed the toner with a new one and when i on my printer the led of toner was glowing and giving the print command nothing was printing again i changed my toner and the same problem arised. i need printer almost most the time so if you could please give me the solution.
  • milov07 Apr 08, 2009
    I replace a new toner but could not print and toner light wont go away. Please help. Thanks
  • thekabuki Apr 16, 2009
    Well, tried covering the sensors, using the reset procedure above, moved the half circle thing back to the 10'o clock position and still nothing. It will print one page...perfectly too-no blotches, no fading, nothing....and then it will stop after the first page.
    any other ideas? It is definitely not out of toner
  • senhkn Apr 16, 2009
    i had same light problem now light problem gone away but this time. it prints out couple of page then windows gives out printing problem :( can any1 help
Found this solution for a 2030 printer. haven't tried it yet but its a suggestion.
had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Mar 19, 2008
The Solution for this problem is:
1. Turn your printer on
2. Open front cover
3. Remove the drum
4. Press GO 1x
5. Put the drum back in
6. Press GO 1x
7. Close front cover.
The LED should stop blinking now ;)
Posted on Mar 30, 2009
What is this solution for ? to reset the printer ? or what ?
Posted on Oct 04, 2008
    Champion:
  • Brother Expert
  • 300 Answers
Nonexxx, you solved my problem.
Thanks buddy
Posted on Jul 22, 2008
Didn't stay working after printing 2 - 4 pages
Posted on Jun 18, 2008
Worked on my 2070N and my 2040 I was going to buy another printer before i saw this and now I have 2 that work.
Posted on May 31, 2008
Thanks for the solution.....works great now. Go figure...
Posted on May 28, 2008
I have a HL-2040 and this worked perfectly. Thanks!
Posted on May 18, 2008
OH, IT WORKS BABY I Promise
Posted on May 15, 2008
Sweet.... it worked well .... thanks... :>)
Posted on Apr 30, 2008
  • glenncz Jan 13, 2011
    Terrific. Saved me a 150 bucks.
  • holgeir_t_k
    holgeir_t_k Sep 25, 2012
    TXH did work, doesent tell you in the manual (why)
Didn't help for me ?!?
Posted on Apr 18, 2008
Worked!!!
Thanks!!!
This problem was driving me crazy.
Posted on Apr 01, 2008
Worked with our 2040.
Posted on Mar 28, 2008
Thanks!!
Works with my HL-2070N too.
Solution worked for me.
Posted on May 01, 2008
SOURCE:
How can I get "Replace Toner Cartridge message to go away?
Pressing the Clear/Back button when front cover is opened. press the arrow down key to show the appropriate toner, then press 1 to reset the bias, close front cover.
Jul 30, 2014 | Brother MFC-9010CN - 17 PPM Multifunction...
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
Mar 17, 2009 | Brother HL 5250DN Laser Printer
Toner light on, will not print
These printers rely on a manual lever on the side of the cartridge to tell the printer there is a new toner cart. The lever has two arms for the 550 (low yield) and one lever for the high yield cart. It sounds like the gears were not reset on the cart. Is the cartridge brand new, or remanufactured? I can give you more info on how to reset the cartridge.....
Mar 10, 2009 | Brother HL-5250dnt Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Ok, now I can help you.
You have a fatel error in your printer. This is unfortunate, but I call them as I see them. The fuser unit has failed and will require replacement. A simple enough task for a technician, but it might take you a little longer. If you hunt around on the internet you should be able to find a fuser unit from a local brother service agent, if they will sell it to you. Otherwise you might be able to look up brother spare parts and you should find something.
Please remember to rate my assistance.
Kindest regards
Gremlin11
Dec 13, 2008 | Brother HL-5240 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Drum light flash Brother HL 2070N
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Feb 27, 2008 | Brother HL-2040 Laser Printer
Toner and Drum Display Reset
After replaceing the drum keep front panel open while holding down the go button. Once all lights turn amber release go button.
If you close the panel the reset does not work.
Sep 14, 2007 | Brother HL 5250DN Laser Printer
Brother HL-2040 Laser Printer Logo
2,584 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
