Question about Kitchen Ranges
Convection oven help
I noticed that the clock light on the oven has gone out and now it doesn't seem to work, when i press any bottoms nothing happens. anyone know what the problem is?
  • travi360 Mar 19, 2008
    there is power coming to the range, the stove itself works, and when i open the range door, the light comes on, so there is power coming to it. I tried switching the switch on th electric panel but that didn't do anything. Ive yet to check the back panel, (im housesitting so a little hesitant to do anything large like moving the range)
    any other ideas or is looking on the back my best bet?
  • 552 Answers
Do you have any other indication that there is any power to the range?
If not check the circuit breakere or fuse in you electric panel.
If there is some indicatioan that you have power coming to the range, then check for a fuse in the range by taking off a back panel and doing a visual inspection.
If no fuse is blown, there may be another visual problem you may see while looking for a fuse.
Otherwise let me know what you see.
Posted on Mar 19, 2008
SOURCE:
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
Tried to change the oven light bulb and when I took it out it said poof and now the whole range is dead. Electricity is going to the unit, but nothing works... not even the clock. Is it gone or maybe...
The first thing I would check, considering you've confirmed there's power at the outlet the oven is plugged into, unplug it. Next, remove the metal panel that is behind the "head," (behind the clock and the controls.) Look for a blown fuse on the circuit board in there. Chances are, that may be all that is wrong. At least it's a cheap fix, and your local Radio Shack should have a replacement fuse for you.
I hope this helps! :)
Dec 16, 2010 | GE 30" Self-Cleaning Freestanding Electric...
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
I have a zanussi zcg7690xn double oven. the digital clock is not working and i cant use the bottom oven. there seems to be power up to the clock as i can hear it buzzing but there is nothing on the display...
I HAVE A ZANUSSI ZCG7690XN DOUBLE OVEN. THE CLOCK IS NOT WORKING AND I CANT USE THE BOTTOM OVEN EVEN THOUGH THE IGITION IS SOUNDING IT WONT LIGHT. I CAN STILL LIGHT THE TOP OVEN AND THE RINGS FINE. PLEASE CAN YOU HELP. AWAIT IN HOPE. REGARDS MO
Jan 30, 2010 | Ovens
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Kitchen Ranges Logo
102 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
