Question about Epson EMP S1 Multimedia Projector
Turns off Projector comes on but turns itself off before I can hit menu and focus to read the menu. The fan then comes on and I have a blinking red light and the power button is disabled. Does this mean that I need a new bulb? Thanks for the help, CD Carter
  • 682 Answers
IF YOU GOT BLINKING RED LAMP FOR 0.5 SECOND -UNPLUG THE POWER CORD AND CHECK THE LAMP IF IT IS BROKEN AND REINSERT THE LAMP AGAIN IF IT IS OK.CONFIRM THAT DOOR COVER OF THE LAMP IS CLOSED FIRMLY.-IF IT IS BROKEN CHANGE IT WITH THE SAME ONE.
IF YOU GOT BLINKING RED FOR 1 SECOND CONTACT WITH SERVICE CENTER.
Posted on Mar 24, 2008
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
Jun 23, 2015 | Sony VPL-ES4 Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
When I hit the start button on my NP 115 it begins to sound like the fan labors and pulses until it shuts down and the red light blinks in a series of 6 blinks. It also has a very hit frequency squeak that...
after 5 minute image go out n power indicator steady light orange n status indicator red light blikns in a series of 6 blinks. in the manual book said lamp error.. what mind "lamp error". please help me.
Jul 28, 2011 | NEC NP115 DLP Projector
In Focus LP 640 won't even turn on? Any help
There are several reasons this could happen, and can usually be identified by glancing at the Power LED. The following applies to this particular projector:
1) Blinking RED led- Lamp or fan failure. Usually this is a bulb issue and simply needs the lamp replaced and the lamp life hours reset. Below you will find an image from the owners manual that will allow you to translate the # of times the LED blinks into a problem/solutionrobertsager.png
2) Solid Red LED means unidentifiable error. You will need to contact customer support at that point to schedule service.
Mar 07, 2011 | InFocus LP640 Multimedia Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Blinking red light
replce lamp ballast board of your projector...
Oct 06, 2009 | Epson EMP 7500 Multimedia Projector
Power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Aug 04, 2009 | Sanyo PLC-XU47 LCD Projector
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Epson EMP S1 Multimedia Projector Logo
296 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
