Question about Nakajima AE-740 Typewriter
CAN'T GET THE MARGINS TO RELEASE
HOW DO I RESET IF THE MARGIN RELEASE BUTTON WON'T WORK
  • Anonymous Sep 10, 2008
    I have something in memory and when we print it stops in the center and we have to turn off the system and try again.
  • lcwilke1 Nov 09, 2008
    I hit return and it won't go all the way back to left margin.  It won't release or backspace.  I have to turn it off to get it back to the set left margin. Sometimes it works right and sometimes it doesn't.  It takes forever to type an invoice.  It doesn't always stop in the same place either when I hit return.
  • Nakajima Master
  • 3,594 Answers
Return to L. mar. touch and release margin rel. key backspace to desired location press l. mar key
DickyO
Posted on Mar 27, 2008
  • 120 Answers
SOURCE: Margin Release
Hold code or features button while pressing margin release.
Posted on May 28, 2008
  • 3594 Answers
SOURCE: Need to reset all the
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
Posted on Jan 15, 2009
  • 75 Answers
SOURCE: Reset Margins
on the upper L.H. side of the key board ther is a button marked MAR REL. turn typ. on press the return key then press the MAR REL key back space to move the carrier backwards or space bar to go forwords. when you are at the spot you need to be fined the button that reads L MRG. press it know your left hand margin is set,
know space the carrier over to the left by the space bar if it stops befor you whant it to press the MAR REL button space to where you whant.
now you have another button saying L MAR
press that and you left hand margin is set. Or the R MAR has small green letters saying L MAR if so you need to hold down the CODE key wile pressing the R MAG key ( any thing in green on key board can only be actavated by the code key ) hope this works
Posted on Jan 23, 2009
  • 3594 Answers
SOURCE: When typing, left margin resets itself at the right margin.
The silver shaft that the carrier rides on is probably gummy put some light oil on it and move it back and forth.
DickyO
Posted on Jan 30, 2009
JayBlair
  • 328 Answers
SOURCE: Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
Testimonial: "Thanks for the information. We don't have aninstruction book with the typewriter. The grandkids like to play with the buttons."
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
How do I do a left or right margin release??
You need to release both the margins before being able to set them again or to get rid of them all together.
To release the margins, you need to press the "alt" button and the number 3.
This should release both the left and the right margins, so if you only wanted 1 reset, you will need to set the one you wanted to keep over again.
Thanks,
Pat
Apr 09, 2010 | Brother SX-4000 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
Margin settings
Sep 05, 2009 | Office Equipment & Supplies
Reset margins
Above the number keys are words in green or blue the margin release, L. mar. and R. mar. are there return to the L. margin, press the alt key with the mar. rel. release them, backspace to the location for the L. mzr press alt and L. margin key, R. margin works the same way.
DickyO
Mar 18, 2009 | Brother SX-4000 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
DicktO
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
Right margin won't release
Try touching the margin release key then the space bar to pass the margin then reset it in a new location with the right margin set key
Oct 16, 2007 | Brother GX-6750 Typewriter
Nakajima AE-740 Typewriter Logo
134 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
