Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Analoge safe mode
How do you get it out analoge safe mode
  • 2 more comments
  • Anonymous Jun 06, 2008
    my monitor runs good enough to see things and work on it....but it is always in a power saving "analog" mode...I want it out of this mode
  • aeiguana Aug 11, 2008
    i try everything but don't get it out of this mode
  • Marie-Anne Gallagher
    Marie-Anne Gallagher Oct 27, 2013
    I did this--i.e. clikt XP Screen, got "Display Properties" window, then clikt "Power" button, and lo & behold found that it was set to turn monitor off after 10 minutes, so I clicked here for the Drop Menu, which was humungously long, with a "Never" at the end. I clikt "Never", then clickt "Apply"; then ok & that screen vanished & I was left w the "Display Properties" window so I clikt "OK" & that window also vanished. I think this may solve my problem but have to wait a bit to see if the Monitor stays on. I'm twinkle & hope to get back to u'all with a thumbs up.
    Addendum to my immediately-previous comment: The screensaver tab is in the Display Properties dialogue box (or window), as Puneet indicated. When I clikt the power button, the "Power Options Properties" box pops up. Beside "Turn off monitor" is where the Drop Menu is where I selected "Never" at the bottom of the list. ~~~~ At first, all this didn't work, so I went back to the sys desktop & right-clikt & learned this time, how easy it is to apparently select all these changes, and then not have them SAVED! So be sure when you see numbers counting down that u click whatever you're posta clik before u run out of time. In short, BE SURE YOU'RE CHANGES ARE SAVED. My computer has now been on for a couple of hours or so since I made this change, and not once has the screen gone black. And nor has that awful word, "Analog" appeared in the upper right corner of my FLATRON LG Monitor! --MAG
  • 90 Answers
Go the desktop, right click with mouse and select properties (if it is XP) then it will open Display properties -->
There you need to go to Screen saver and then to Power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Posted on Nov 13, 2008
  • Puneet Jain
    Puneet Jain Nov 13, 2008
    Otherwise, go to Control Panel there you will find the Power Management or Power Option.
    Either disable the Sleeping mode, Power saver or you can choose the option say 1 Hour, 2 hours etc.
    Thanks
Power but no display
It could be a hardware or software problem. You need to isolate the problem.
To isolate the problem, restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode. Hit enter.
If you can boot to safe mode, then do a system restore inside safe mode to revert the computer config back to a known good date.
If you can't boot to safe mode, then it's for sure a hardware issue and you need to get it serviced by a technician.
David
May 26, 2013 | Toshiba Satellite Computers & Internet
Message on monitor says " no analog signal".
If you are getting no post display on boot up (dell spash screen, and windows loading screen):
First step is to plug a different monitor into the computer. If this works you most likely have a bad monitor. If not then it is a hardware issue with the video card on the computer.
If you getting the post screen then you may have your resolution set to high, boot in safe mode (F8 on the key board right after the post screen) and chose safe mode. once windows comes up, right click the back ground and chose a lower resolution setting.
Hope this helps
Oct 17, 2011 | Dell OptiPlex GX620 PC Desktop
Its all black, it says Analog power saving mode, then it turns black again, how can i fix it?
Try to boot it on safe mode by pressing F8 key while startup. And goto start>control panel>power option and uncheck all power saving modes. Then restart. Hope it helps.
Jul 29, 2010 | Computers & Internet
When starting the computer, after the Windows XP logo screen, I get a black screen that reads "Analog input cannot display this video mode." When I clear that screen, I get a blue screen with the following...
Boot your computer2_bing.gif to safe mode and change the display settings to either 800x600 then save and reboot2_bing.gif once it comes back up you can change the display setting to what you prefer.
To get into safe mode press F8 on you keyboard2_bing.gif every second while it is first booting up.
Mar 09, 2010 | Microsoft Windows XP Home Edition
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I have an lg monitor, when i start up it goes to analog power save mode how can i fix this problem?????
If you do not have a display then restart to safe mode, right click on the desktop, choose Properties, Settings then Power Saving. The options for Power Saving mode are displayed. Steve Medley
Nov 07, 2008 | Computers & Internet
Analog Power Saving Mode
I need more detail. Can he get into an operating system (Like windows?) Does he ever see a picture? At what point does it freeze? Can he access the system bios?
More detail please
Mar 27, 2008 | Computers & Internet
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
212 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
