Memory upgrade problems
Acer aspire 9810 series
When updating memory from 1gig to 3 gig (similar specs and speed)computer locks up when coming out of hibernation etc.
comp uses vista home premium (32BIT)
  • terramam Oct 14, 2008
    Acer Aspire T650-997Z whit two slots for memory 2X512MB-Nanya NT512T64U88A0BY-37 DDR2 DIMM.After trying to change whit 2X1GB Transcend JM667QLG 240pin DDR2 DIMM my PC ,runing WinXP boot BIOS,but going just to screen when asking me how to start Windows-normaly or in safe mode and after i choose normaly, blink blue screen and follows reboot.
    I try to run it whit old memory module and it works.Both Transcend moduls are working but only in combination whit the old  one-in the first slot 512MB Nanya and in second slot each of Transcends moduls.I'm wondering why this happening,and how to solve it?
  • 4,234 Answers
Try maxing out at 2 gigs and try again. It is possible that the motherboard can not address more than 2 gig. If that is the case, the extra gig will respond at the same time as another 1 gig set causing confusion to say the least. I can provide more details if required.
Dan
Posted on Mar 19, 2008
I have an ET1161-05- can it be upgraded to hold more memory and run faster?
Hi.
Yes, your computer came with 2 gig's of ram in the form of 2 1gig modules of ddr2 ram.
There are 4 slots for memory all together, and each slot can hold 2 gig memory chips in each one, for a total of 8 gig's of ram!
That would cause a serious performance improvement for you.
It also came with a 160 gb hard drive, so if you want to, you can get as larger drive as well.
As far as processors, a dual core, AMD Athlon 64 X2 5600+ Brisbane 2.9GHz 2 x 512KB L2 Cache Socket AM2 65W processor will fit in with absolutely no bios updates required, so all you would have to do is take the old processor out, put the new one in, and turn the computer on.
It will recognize the new processor automatically, and will work right away!
This will have a significant performance boost, possibly doubling the total speed of your computer.
I hope this helps you out, and have a good day !
May 26, 2011 | E-Machines eMachines Desktop PC
Hi.. i have a Lenovo laptop model 7757 with Support DDR2 533/667MHz DRAM with dual channel... It has a 1gig memory and i want upgrade it to 3 or 4gigs.. is it ok if i'll put in 2gig memory in the other...
Yes, with this model, Mix and match is ok. Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 512MB and one 2GB of memory for the total of 2.5GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules.
Apr 12, 2011 | Lenovo 3000 Y410 Laptop
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
Hi have an Acer Aspire 9815k (9810). Just
Sounds Like a driver issue. Uninstall the Sound drivers in the device manager, and check with the Acer website and download the appropriate drivers for your laptop.
Oct 22, 2009 | Acer Aspire 9810 Notebook
Compaq Presario S4300CL PC Desktop is SLOW.
You said you have 512K of RAM; I assume you mean 512MB. Either way, you are in dire need of a RAM upgrade. The sweet spot for XP memory-wise was 2gigs. The working minimum is 512MB, but the recommended spec is at least 1. If you upgraded to at least 2 gigs of ram, you'll see a speed improvement.
If you need help finding out what type of memory to get, let me know.
Mar 14, 2009 | Compaq Computers & Internet
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
Acer aspire 9810 memory problems
Two things you can check.
1) Verify that the Acer doesn't require a jumper change on the motherboard to support more than 2 Gig.
2) Verify that the particular version of Vista that you have will support more than 2 Gig as well. It is possible that the Vista installation process "checks" for available memory and loads based upon that number. I don't know that for sure, but other software has done this in the past. It is best to check.
Dan
Mar 20, 2008 | Computers & Internet
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
Increase Memory.
no u dont need look @ the bios>if u insert it properly that should display it if it is not then teh card is bad>or the slot on the board if the solt works with the other card then there is no issue with the slot so replace it rate me solved if its help full thx
Nov 05, 2007 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
136 people viewed this question
David Payne
David Payne
