Question about ASUS P4V8X-X Motherboard
SATA problem Hardware iniatiate failed. please check device The bios not be installed
  • zangetsu001 Apr 19, 2008
    i have an asus p4v8x-x mobo and ive just bought a hitachi sata hdd 160 to get more capacity.i was using an ide hdd and still using it. i have connected the sata hdd to my mobo and i receiv the error "hardware initiate failed press g to continu" can anyone help me about it?
U can check the SATA cable and power supply for SATA or replace it....if still not working u can buy a 1 liter of gasoline and 1 pc. of match and burn it...to ease ur problem.... ;))
Posted on Nov 13, 2008
  • yawza Nov 13, 2008
    if my solution is bothering you still have one solution.....u can contact me and pay me to fix that problem if i cant fix it ill be the one who will burn you together with your pc .......GAGO pinagloloko nyo kami.....paluin mo nlang ng martilyo yan para matapos ang problem nyo....ENG-ENG....
I have the same problem. After the message "hardware initiate failed press (g) to continue" appear, press the "reset" button then the SATA controller should detect the HD. Now I have a problem with SATA DVD-RW drive. My XP can't read any CD/DVD but it can eject the drive.
Posted on Oct 22, 2008
    President:
  • 2,351 Answers
Your bios is corrupted & needs to be flashed.
You will need to download the bios flash utility & a bios file.
creat a floppy disk with these to files that you can download from here. Click the link below.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
If you are not comfortable with flashing your bios you can order one from Asus by calling 510-739-3777 CA. Please have your model Number ready & S/N located on a white sticker on the pink serial port.
Good Luck!
Mike
Posted on Mar 20, 2008
I have P4V8X_X(ASUS) and i have just found the answer to this problem of SATA that cannot be detected...but i will not put the solutions here for now. if you want to know what i did to make it works then, contact me and i will teach how to... :))
Walang personalan tol, Trabaho lang..hehehe "PEACEYA^^
sipon_047@hotmail.com
Posted on Jan 12, 2009
I was update bios but it still same
can solve ?
Posted on Sep 13, 2008
can solve ?
How to install sata HD on this motherboard P4V8X-X? the hardware cant be found the bios dont have any sata support
Posted on Sep 09, 2008
EP-8KRAI motherboard does not see WD2500AAKX SATA HDD
check the cable
make sure the hd is getting power
try another sata connection by swapping the cable from dvd device
make sure you set the drive select some drives require it
do not use cable select
make sure the battery back up has 3 volts
you could try shorting out the bios to reset the motherboard - there should be a jumper on the board, turn power off, the jumper or connect the two pin so the short out, than turn on machine, just for few seconds and turn off, remove the jumper.
xxxxxxxxxxxxxxxxxx important xxxxxxxxxxxxxxxxxx
before or when booting the system push F10 to access bois
setup all devices, dvd, video card, if that dont work you can try F1 or F2 when you start the system
when you exit the bios make sure to save it i think F10 save and reboot. so save new changes and device ID.
Apr 16, 2015 | EPoX EP-8KRAI-X Motherboard
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Install a 2nd hdd (sata) on dell optiplex 360 not working
Can the disk viewed in disk management?
Right Click 'My Computer'-->Manage-->storage-->Disk Management
Disk 0 usually for windos partition (your 80GB HD)
If Disk 1 (your TB HDD) show unallocated, you need to format it to NTFS.
Right Click and select 'Format'.
!!!!Make sure it is your TB HDD!!!!!!!
Jun 08, 2012 | Dell OptiPlex 360 Desktop Computer
I pulled a jumper off sli motherboard my cd rom is not reading disks alienware alx
Assuming you can eject disks, and the drive is appearing in my computer / windows explorer, check the SATA (usually red) cable connected between your drive and motherboard, If it is correctly connected try using another SATA port on your motherboard, if that doesnt work you can try going into the bios (usually by pressing delete as it is booting) then checking to see if the drive is being detected, you should see it in SATA devices, and also in your boot menu. If it isnt there its a hardware problem.. replace cables, try using the SATA port from one of your Hard drives.
If the drive is in showed in bios, and
is not appearing in my computer / windows explorer, go into control panel, system, hardware, device manager (if using XP, other versions of windows also have device manager) if there is a yellow question mark next to the dc/dvd drive, run the installation cd for your drive, or right click, update driver, run through the wizard selecting the location where you saved the drivers.
If it is installed correctly, and you have tried numerous disks, making sure they are not dvd's if its a cd drive, the you can try downloading the bios file from the manafacturers website and updating following their instructions
Mar 06, 2011 | Alienware PC Systems Alienware Aurora High...
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
How do I install a SATA DVD drive in my 655A V1.0?
Hi stewwiles, If your bios does not see & list the drive neither will windows hardware manager/ device manager. Check your manual. Enter your bios. The DVD drive should be listed in the same menu as your hard disk drive. Than go to the title "Boot" in your bios & make sure your DVD is listed in the boot order. (List of normal boot order):
1st boot device= Floppy drive
2nd boot device= DVD drive (model no#)
3rd boot device= Primary hard disk drive (model no#)
Make sure your DVD's jumper setting is set to "Master".
Mike
Nov 13, 2008 | Foxconn Computers & Internet
Computer will not boot to desktop
1. Unplug the SATA drive and see if you get a desktop then.
2. If so, then go to hardware/device and look for PCI sata card.
3. If it is listed, check the details, copy down and post here.
4. If it is not listed, see if it is listed under computer management/hardware/devices or in the "problem device" or "conflicts" tabs. Post any mention here.
5. While I wait for your reply/you wait for me to catch it, you should also try switching the card to another PCI slot. Sometimes, with new technology added to older boards, the slot ID is important.
Feb 23, 2008 | AOpen AK77-8XN Motherboard
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Hdd
your board may support sata however it may support sata 1 not 2 and your hdd may be a sata 2 one..so all you have to do is to check the hdd jumper and set it on sata 1 and also check the bios for the right settings to be made...
good luck
bye
Feb 09, 2008 | ASUS P4V8X-X Motherboard
ASUS P4V8X-X Motherboard Logo
1,154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
