Question about Canon MV750i Mini DV Digital Camcorder
Tape mechanism I have a Canon camcorder which takes Mini DV tapes. The mechanism for the tape (i.e. inserting and ejecting) works fine until I try and put a tape in the slot - The camera whirrs, bleeps and then ejects the (brand new) tape again. It seems like a very small problem and easy to solve; what do you think? Dan
  • paddy086 Sep 15, 2008
    i have the same problem and down know what to do
  • fr1pp3r Jan 26, 2009
    I too have this problem. One solution mentions the flexi pcb???? Sorry, but you've lost me!!!
This sounds bizarre I know, but I read another threat regarding Canon camcorders and tapes self ejecting. The advice was to ........ wait for it........ drop it onto a carpet floor from about 1/2m. My wife top me not to consider it. I continued reading and someone else had been successful using the technique. I have to report that it actually works. I dropped it (twice for good measure) and it loads tapes once again. Its true what they say, if in doubt....give it a clout!!!
Posted on Jan 27, 2009
I dont believe it. Dropping it on the floor really does work. I only dropped it about 5 cm from the ground and it worked straight way. Strange but true.
Posted on Jun 03, 2009
    New Friend:
  • 52 Answers
Hi.
Sounds as though the tape drive motor is failing to drive. Not as simple as it sounds. In the past, I simply checked that the flexi pcb from the tape drive motor was pushed right into it's connection after inspecting it for moisture damage. Luckily, i needed to look no further.
Posted on Oct 10, 2008
Canon ZR300 Mini DV Digital Camcorder THE MINI DV TAPE IT DOES NOT GO INSIDE THE CAMERA, SOUND LIKE IS GOING BUT IS EJECTED WITH A AUDIO WARNING AND IN THE VIEWFINDER SAY REMOVE THE TAPE AND A X APPEARS,...
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
Nov 03, 2010 | Canon ZR300 Mini DV Digital Camcorder
I was getting a message clean heads, so I bought the cleaning mini DV to insert. I pressed the button to open the door where the mini DV tape is and it popped up, but will not pop open to release the...
It sounds like something has jammed the tape door mechanism preventing it from opening. This is a very delicate part of a mini DV camcorder. I would highly recommend taking it to a electronics repair shop where it can be checked out. If you try and force the tape out you will probably cause considerable damage to the tape transport system making your camcorder unusable.
Take Care,
Aug 09, 2010 | Canon Optura 50 Mini DV Digital Camcorder
Will not eject mini dv tape
I had the same problem. I cycled through the eject process until it finally gave me back my tape. I had to send it back to have the tape carriage replaced
May 03, 2010 | Canon Optura 20 Mini DV Digital Camcorder
I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
Dec 19, 2009 | Canon Elura 65 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Tape insertion
It's dirty inside, you need to send it off to be cleaned.
Nov 28, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Canon MV750i Mini DV Digital Camcorder Logo
189 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
