Question about Car Audio & Video
Hifonics collossus need subwooofers for this amp any suggestion
  • Tygh Duval
    Tygh Duval May 11, 2010
    How much do you want to pay?
  • 27 Answers
This decision is up to you, how much room you have for an enclosure, what type of music you listen to, and how much money you wanna spend. Whatever you choose make sure you're getting a sub that can handle the amps RMS wattage per channel.
Posted on Mar 21, 2008
Im looking for a company that sales hifonics samson xi line input that broke of my amp..
Hifonics is sold by Maxxsonics
http://www.maxxsonics.com/hifonics/
You can contact them at support@maxxsonics.com
Feb 28, 2011 | Hifonics Generation XI Thor Car Audio...
Where should i take my amp to get fixed
Hello
OK, depending on where exactly you live, i would suggest that you take your amp to your nearest auto audio repair store.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Nov 09, 2010 | Hifonics Brutus BXi 1206D Car Audio...
How to conect a hifonic amp class d to four
+ too - & - too + & + too - & - too +& + too -
Apr 01, 2010 | Hifonics BXi1608D Car Amp
Need mosfets for hifonics amp sfp50n06
That is a Semiwell part I believe. It is an N-Channel power mosfet. Go look on their website they may have an alternate part you can use.
Dec 18, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics BXI 1606D problems
it may be a wiring problem you need to make sure all the speaker positives and negatives are correct. I sell alot of hifonics amps and have never had 1 do that. it may also be a bad rca cable. if it only does it when you use the filter i would say not to use it also make sure the gain is no more than 3/4 turned up and the bass boost no more than 1/2. if you have a dif amp try a temp setup using it and if it still does it its a wiring issue. also try 1 speaker at a time on the hifonics and keep adding 1 till it comes back it may be a bad voice coil on 1 sub .
Jan 08, 2009 | Hifonics BXI 1606D Car Audio Amplifier
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics Taurus circuit diagra???
You need to measure the voltages at the output transistors. The previous "driver" stage may have a problem. These outputs use .6V as the bias differential. Check for DC voltage on the inputs to the transistors. These are standard designs. I'd check for DC anywhere along the signal path.
Dan
Apr 09, 2008 | Hifonics Brutus BX 1505D Car Audio...
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Jan 01, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
53 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
