I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card
either by connecting to pc via USB or using an SD adapter. Next, Tap on
the Music Player, open the music list, press the menu button and select
PLAY ALL, this will scan your SD card for music/audio files. Once all
your songs have been added to the list, select the song you want to set
as ringtone and click MENU key, choose SET AS RINGTONE and that will take you
to the RIngtone Trimmer, make the ringtone 30 seconds or less, select
Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it
HeroRIngtones, HTC, or whatever and put there all the ringtones you want
to be added (30 seconds or less), then open Command Prompt; make sure
your device is connected and already visible. Run the following command
"adb push directoryname/myringtone.mp3 /system/media/audio/ringtones"
and press enter. Do same procedure for all the audio files you want to
set as ringtones.
Method 2 is not available for non-root users.
