Question about Saeco Odea Giro Plus Coffee Maker
Saeco odea giro
I just got one of these machines about 2 months ago. I has been great. Two days ago I went to make a coffee and it started then seemed to "freeze" up. I turned it off and unplugged it to try to reset it. Once I plugged it back in, everything was dead. There seems to be no power anywhere. I am wondering if there is a reset button anywhere.
  • 1 more comment
  • papaloader Apr 03, 2008
    It appears that the main board is the problem. I got this machine in the USA. Now neither Seaco USA or Saeco Canada will stand behind it.
  • papaloader May 05, 2008
    I found more out about the reputation of Saeco.
    http://cleveland.e-asp.net/Nis4/bbbrepor...
  • papaloader Jul 11, 2008
    I took this machine into a recognized repair shop by saeco and they took it apart and the board was definatly burned up in one spot. It cost me over 100 dollars for the diagnosis and was told it would cost between 400 and 450 for the repair. but I thank you anyway.
    New Friend:
Yes that makes senses, but how do I reset the fuses? I cannot connect to the link provided and cannot find guidance anywhere. Nothing on "How To Simplified". Thanks.
Posted on Oct 30, 2016
  • 74 Answers
Yes it might be the main board. but i would first try reseting the Boiler automatic fuses
Posted on Jul 11, 2008
  • Anonymous Jul 11, 2008
    Changing the main board is very simple.
    if it they know what they are doing it wouldent take more then 10 minutes.
SOURCE:
Grinder problem
try to check the brew group
Jun 18, 2012 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
Saeco Odea Giro - Clogged and coffee come out in water tray....
This has happened to our machine that we use for our youth group. We sent it in and they said it was clogged also. Not having a clue what they meant. It happened again and I figured it out. When you remove the brew group there is a hole just above it that dispenses into the brew group. Make sure it is not clogged. Give it a try Good Luck
Mar 08, 2009 | Saeco Odea-Giro Espresso Machine
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Dec 09, 2008 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus Coffee Maker Logo
1,718 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
