Question about Acer AOpen AX4BS-V (91.89J11.001) Motherboard
4060 one of the chip on the motherboard is very hot so the the system can`t on
  • 117 Answers
Apply the heat sink paste in original paste that problem is solved
Posted on Mar 21, 2008
How do I check the internal wiring for input voltage on a Marantz 4060 Quad Amp?
The only way would be a voltage selection switch on the back of the unit, or changing pigtail leads on the primary side of the power transformer.
Apr 30, 2014 | Marantz MA-9S1 2-Channel Amplifier
When I try to play my ps3 it will freeze up and show these red and green lines on my tv
This is a GPU chip problem, it has a bad connection to the motherboard, that can cause YLOD, no picture, freezing, pixilation, no hard drive activity, no synchronization with the controller through the USB cable , colors get missed up , see lines and different forms of pixels on the screen then it freezes, all these symptoms indicate a bad connection between the GPU chip and the motherboard, there is only one real solution , Reballing the GPU chip , PS3 GPU chip is a very sensitive chip due to the fact that it has a built in memory chips so you need a very reputable place to do that procedure for your console , the photo story you see is an example of the reason and the solution and the link is for the place to fix it for you and give you a one year warranty on the repair.
56c8f7ed-37a5-4044-aae4-c4667c5361b8.jpg 0080ee9a-6834-4bf3-aa92-040ee20db882.jpg PlayStation3 GPU Reballing service
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
Port forwarding sonicwall 4060
Check port setting option policy setting
Feb 06, 2014 | SonicWALL pro 4060 security appliance...
Motherboard overheating
Try to change your psu and add/change system fan
Oct 22, 2012 | HP (350030-001) for Compaq dc7100...
As i was upgrading my bios, the power went off, after restarting no display, what can i do? my laptop is hp compaq nc6400
The machine will not start again until a new bios chip is installed or the
board is replaced.
On a desktop a procedure called "hot flashing" can be done but not on a
laptop unless you have the proper equipment and know-how.
Hot flashing is where you get and identical bios chip and replace the one on
the board. After the system is started you pull the chip will the system is on and
replace it with the bad flashed chip. Then you do a regular bios flash upgrade. The key is you
need an identical bios chip to start the process. On a laptop you need either and a identical
chip or the ability to write to the bad chip. Oh and I forgot to mention you need the equipment
to take the board out of the laptop case and get it running
One of two things needs to be done:
1) Replace the motherboard
2) Find someone who knows what they are doing and remove the chip and
reprogram it. You should be able to find one of these guys under Google.
May 12, 2011 | HP Compaq NC6400 Business Notebook
My mainboard can't on I touch on chipset VT8237R very hot. What can ido to repair this mainboard ?
Unless the motherboard is malfunctioning, I wouldn't really worry about it. If Asrock didn't put a heatsink on the chip you're touching, that means that the chip was meant to get that hot for the lifespan of the motherboard. If you're really anal about it, you can increase the cooling in your case by adding better fans, or even go liquid cooling and buy a waterblock for the chipset and cpu.
Mar 09, 2011 | Asrock 775VM800 Motherboard
Its makes my pentium 4 go to 136 C, the temp rises in a matter of minuets! no other motherboard does this, and no settings have been changed! please help!
Are you sure the reported temperature is correct? How are you getting this indication? Is it through the Hardware monitoring in the bios, where the system would be under little load?
Have you checked that the heatsink is getting that hot? 136 degrees c is enough to blow the chip and I would have thought the computer would have shut down. placing your hand near the heatsink should tell you if its getting hot even without touching it
I would be inclined to download a hardware monitoring programme that will confirm the temps that you appear to be getting. If the chip is not running that hot it may be a faulty sensor.
To help resolve this, I would reset my bios to the defaults to eliminate that area first, then check my heatsink and fan to clean any dirt or dust build up. I would also try another chip to see if the same problem occurs. It COULD be a faulty chip
If the above produce no results, and your motherboard is set to defaults, then I would seriously consider swapping out the board.
I don't know what cooling fan and sink you are using but the Precott P4's used to generate a lot of heat and ran ay 75 degrees on a standard cooler, certainly recommend a copper bottomed or Arcic cooler pro type
Dec 30, 2010 | HP Asus Motherboard P4SD-LA Socket 478...
Chip fan failure... seems, the board does not start until the temp is cool . does this board protect the chip by not startingis the chip is too hot?
Does the fan still spin when it does power on? The protective measure of the board is that when the chip is too hot it will still power on but only for a second, then it will turn off with a beeping sound. If you suspect that the chip is too hot you might want to measure the temp. One other thing you could do is to reseat the Heat Sink and Fan assembly and make sure there is ample thermal paste.
Jun 07, 2010 | Evga (131-K8-NF44-AX) Motherboard
Cooling fan runs continuasly even with ignition is no switched on
Even when the key is off with the engine cool after a few minutes? Or just a few minutes after it is turned off with the key?
Check or change your thermostat and flush the radiator with the heater running on hot as it can be. Can you see inside the radiator? If you can is the water flowing good? If it is not after you change you thermostat and it still runs hot then it is your water pump. Is it running hot?
Please answer the questions before you rate this.
Jun 22, 2008 | 3Com Fan tray - for Switch 4050 / 4060
Motherboard doesn't wake up the monitor
Place your finger on the heatsink for the chipset. Feel around for any extremely hot chips. If you find this, your Bios is shot. If you cannot locate the bios chip, just feel all the chips. The Bios chip should be mildly warm but never HOT!
Feb 19, 2008 | ASUS P4SGX-MX Motherboard
Acer AOpen AX4BS-V (91.89J11.001) Motherboard Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
